Author Topic: S1 336-08 Transaxle LEAK!!!!!!!!!!  (Read 1570 times)
Re: S1 336-08 Transaxle LEAK!!!!!!!!!!
« Reply #15 on: Tuesday,May 13, 2025, 09:20:46 AM »
   Just some of my experiences here.
https://www.lotuseuropa.org/LotusForum/index.php?topic=2058.1125
  My original gearbox pictured was about 3 drops per side, after a gearbox change to get some idea of what I purchased as backup, leaks terribly.
Offline My S1
« Reply #16 on: Thursday,May 15, 2025, 12:10:32 PM »
Crazy idea just came to my scrambled brain;  is it possible to put a latter 365 crown wheel bearing nut with external seal on my early internal seal 336 to double up the sealing power?  I spotted this external seal crown wheel nut on the SJ Sportscars site.
Online HoraceM22
« Reply #17 on: Friday,May 16, 2025, 01:41:57 AM »
After rebuilding my engine and getting the transmission back in, me and my nephew had a whole load of trouble getting the second (L/H) driveshaft in to set the spacer washers and eventually realised that loosening the trailing arm bolt would give us a load more free play. I didn't touch the rear uprights at all. That might help you.
I now have my own gearbox leaks to address, on  a new post.
HoraceM22
