Author Topic: Where does this ground go?  (Read 452 times)
« on: Wednesday,May 21, 2025, 09:14:45 AM »
It’s near the steering wheel …. :confused:
Offline My S1
Re: Where does this ground go?
« Reply #1 on: Wednesday,May 21, 2025, 09:23:52 AM »
Just a guess, but on my S1, I have a similar ground which attached to the right side steering column mounting bolt.  It is a redundant ground as the steering column U joint is also grounded to the rack.
« Reply #2 on: Wednesday,May 21, 2025, 09:24:07 AM »
I can't tell the color of the wire - calling it a ground implies black - but it looks like it's a PW (purple/white or white/purple) which means it goes to the courtesy door switch which then has to be grounded. Am I close?
« Reply #3 on: Wednesday,May 21, 2025, 11:09:47 AM »
It’s black …. I am thinking steering column ground as My S1 suggested (thanks S1!)
