Author Topic: Smiths Speedo Cable 90 Degree Adaptor  (Read 1567 times)
Offline My S1
« on: Monday,April 07, 2025, 09:39:48 AM »
A friend of mine who owns an S1A said that he had a recurring problem with his speedometer cable breaking due to the tight bend required at the gauge back.  Has anyone else with an S1 experienced this problem?  He suggested a 90 degree adaptor but I'm unable to find one on the internet.  Any suggestions or sources?
Re: Smiths Speedo Cable 90 Degree Adaptor
« Reply #1 on: Monday,April 07, 2025, 10:06:05 AM »
Summit Racing has something that might help (https://www.summitracing.com/search/part-type/speedometer-cable-adapters?page=1). Amazon has 90° tach cable adapters which might work (https://www.amazon.com/s?k=90deg+tach+adapter&i=automotive&crid=208OPFETX7BJP&sprefix=90deg+tach+adapter%2Cautomotive%2C66&ref=nb_sb_noss). Autometer has this (https://www.autometer.com/catalogsearch/result?q=speedometer%20cable%20adapter).
Searching "90 degree speedo drive adapter" (no quotes) on DuckDuckGo gave me those and several more hits.
Offline My S1
« Reply #2 on: Monday,April 07, 2025, 10:58:41 AM »
The difficulty that I'm having with the search is the thread size and count.  Mine measures out at 1/2" (12mm) with approximately 27 TPI.  It is in kph, not sure if that has any bearing on the subject.
« Reply #3 on: Monday,April 07, 2025, 11:26:12 AM »
Have you tried Smiths dealers like Nisonger (https://nisonger.com/) or repair shops like North Hollywood North Hollywood Speedometer (https://www.nhspeedometer.com/)?
« Reply #4 on: Monday,April 07, 2025, 12:55:42 PM »
It's a standard size for smiths/jaeger speedos.  I used a 90 degree adapter as they used in MGAs and Bs back when.  Never had a problem in 14 years of owning 693R after breaking a cable every month or so.
Offline My S1
« Reply #5 on: Monday,April 07, 2025, 03:07:49 PM »
I'll track one down.  Thank you.  Do you recall where you sourced it from?
Offline My S1
« Reply #6 on: Monday,April 07, 2025, 03:16:44 PM »
Bryan,
I think I found it...thanks to you.  I'll double check with them on the thread size.
« Reply #7 on: Tuesday,April 08, 2025, 12:40:59 AM »
« Reply #8 on: Tuesday,April 08, 2025, 11:50:14 AM »
https://rimmerbros.com/Item--i-120694OE
Not cheap !!!
neither is replacing the cable 2 or 3 times.  They seem to be a bit cheaper on this side of the pond.
Offline 314159td
« Reply #9 on: Tuesday,April 08, 2025, 05:43:00 PM »
