Author Topic: Shot in the Dark to Find a Tool  (Read 821 times)
« on: Friday,December 13, 2024, 11:48:20 AM »
Figured I'd ask here before bothering a local machinist...but does anyone know where I could score (beg, buy, borrow...) Lotus Tool T.339 as found on page 31 of section L of the Twin Cam supplement?  It's the tool to drive in the throttle spindle seals.  Guess I could bodge something up...but might be nice for once to use a tool meant to do the job I'm trying to do...just sayin.
Re: Shot in the Dark to Find a Tool
« Reply #1 on: Friday,December 13, 2024, 12:36:31 PM »
Bryan, if no one out there has the factory tool to lend out, send me a PM. I have a mini lathe sitting unoccupied. Not that I have nothing else to do, but looking at the drawing specs, it looks fairly simple to replicate. For a professional machine shop, probably less than an hours worth of work. My machinist charges $125/hr, so consider what it would cost you to make the tool. I'm just a novice in machining but it looks simple enough.
« Reply #2 on: Friday,December 13, 2024, 12:51:10 PM »
With my occasionally used mini lathe, I thought similarly. But if you consider the 8.2 mm reamer as a cost (I don’t have one  :-\) $125 might not be too out of line. Still, it would be fun to machine.
« Reply #3 on: Friday,December 13, 2024, 01:05:21 PM »
I recommend seeing what a machine shop will charge for such a simple tool first.
« Reply #4 on: Friday,December 13, 2024, 01:11:27 PM »
Gong to ping Steve V, since he seems to have touchpoints at machine shops.  I don't know if the 8.2mm is space program critical...only meant to fit over the throttle shaft (if it's in the body...if not...then I don't think it would matter; the seals go on lips out (which means the machining on the end is meant to press the seal onto and then press into the body of the carby, I think...)
Going to suss this out; appreciate your offer, Jojii...
« Reply #5 on: Friday,December 13, 2024, 02:31:29 PM »
I think a 21/64 drill bit (8.33mm) would be close enough to line it up with the throttle shaft! That's only .005" over ....
« Last Edit: Friday,December 13, 2024, 02:35:18 PM by TurboFource »
« Reply #6 on: Friday,December 13, 2024, 03:04:16 PM »
Even though we're not building parts for the Mars Orbital Lander, if a tool is available with the right size and not exorbitantly expensive, I prefer using the right tool. A 8.3 mm reamer is about $6-$7 online.  Pretty cheap for a probably one use only tool. Hey Bryan, go ahead and get a quote for the tool. I'll start ordering the material and the reamer to make one for myself. If it turns out usable, I'll mail it off to you. I also need the practice.
« Reply #7 on: Saturday,December 14, 2024, 07:34:42 AM »
That would be great...fwiw, if you were into the r-16 engines...I have the head locator studs and tool, and liner nip block sitting in a box in my garage.
« Reply #8 on: Saturday,December 14, 2024, 09:39:55 AM »
I've fit lots of seals to Strombergs.  It's a simple job.  Use a deep socket that just slips over the spindle.
