Author Topic: wheel studs 3/8-24 knurld 13.1mm and about 50-55mm long  (Read 928 times)
Offline Adde
« on: Friday,November 05, 2021, 02:42:26 PM »
Hi
I just got a new set of wheels for my Europa-68.
The problem is that the new set of Europa wheel studs that I also bought is to short. ​
Anyone that know where to order longer wheel studs 3/8-24 knurld 13.1mm and preferably about 50-55mm long (in total)
/Adrian
Offline SwiftDB4
Re: wheel studs 3/8-24 knurld 13.1mm and about 50-55mm long
« Reply #1 on: Friday,November 05, 2021, 03:21:18 PM »
Demon Tweeks U.K. has 50 and 60 mm long 3/8"
https://www.demon-tweeks.com/us/grayston-wheel-stud-243674/
You might also consider going to 7/16" studs and lugnuts while you're at it.
« Last Edit: Friday,November 05, 2021, 03:25:35 PM by SwiftDB4 »
Offline SwiftDB4
« Reply #2 on: Friday,November 05, 2021, 06:35:37 PM »
Sorry but those studs don't have the correct knurl. This is as close as I can find:
https://rimmerbros.com/Item--i-21H5774XL  in 48mm length.
As I said 7/16" studs are stronger and easier to get longer ones so might be a solution.
« Reply #3 on: Saturday,November 06, 2021, 12:14:05 AM »
I fitted 12mm studs when I moved to 15" wheels, but still ran 13" wheels with the larger studs for some time. I know the lighter studs work fine with standard Lotus steel wheels and alloys, but there's got to be a reason that most modern cars have moved to using larger studs.
http://www.lotuseuropa.org/LotusForum/index.php?topic=219.msg1314#msg1314
At the time I never even considered the pattern of the hub end, it's going into a plain hole so as long as the diameter is is a press fit, it's going to work ?
« Reply #4 on: Saturday,November 06, 2021, 05:52:14 AM »
I'd drop them a line for more details specs.
https://www.johnbrownwheels.com/accessories/wheel-studs
Offline Adde
« Reply #5 on: Sunday,November 07, 2021, 06:48:46 AM »
Thanks, It was actually from johnbrownwheels that i bought the new wheels. I will drop them a mail.
Thanks, yes I have kind of realised that changing studs and nuts to a thicker dimension is what most have done. Maybe I need to walk down that path as well. But as I just bought a compleet set of wheel :-\
As I said 7/16" studs are stronger and easier to get longer ones so might be a saolution.
Yes, I might end upp there.
Offline kram350kram
« Reply #6 on: Thursday,November 11, 2021, 04:48:12 PM »
Speaking of wheel stud replacement, thought I would post what I found when replacing the stock studs to 12mm. Didn't notice it until I really inspected.
« Reply #7 on: Thursday,November 11, 2021, 04:51:21 PM »
Mine look necked down like that, too. Something to replace before the car gets on the road.
« Reply #8 on: Thursday,November 11, 2021, 05:03:19 PM »
How tight were they torqued?!! They only need 40 - 45 ft.-lbs.
« Reply #9 on: Thursday,November 11, 2021, 09:52:47 PM »
Wow, someone's been really heaving on that wheel nut, I can't imagine that's happened due to cornering loads alone. Maybe tyre fitters with impact guns is the reason most modern cars have stronger studs !
« Reply #10 on: Monday,November 15, 2021, 10:35:42 AM »
Pleasures of having a tire place use air powered impact wrenches to tighten wheel nuts. "Works for a big-ol Chevy, outta work for this little car."
