Author Topic: Wiring Diagrams  (Read 2385 times)
Wiring Diagrams
« on: Saturday,July 24, 2021, 03:16:48 PM »
  Came across this jewel of a hook up. Is this real or a mistake?  See pics.  Turn indicator connection.
  As many of you know I’m going thru all the wiring diagrams and seeking commonality. Getting them all down to the least common denominator. I can easily see the S1 and S2 diagrams simplified to the tc and tcs level..
   Federal tcs
Re: Wiring Diagrams
« Reply #1 on: Sunday,July 25, 2021, 03:30:47 AM »
Where is the flasher unit in that diagram?
Re: Wiring Diagrams
« Reply #2 on: Sunday,July 25, 2021, 05:12:14 AM »
   4129,  :trophy:
   That’s correct, master tc fed needs a tweak to this. People could also cut and paste a sticky note to their printouts.
Re: Wiring Diagrams
« Reply #3 on: Sunday,July 25, 2021, 08:02:42 AM »
Steady on guys, that's wrong.
The turn flasher unit is the left hand square shown just above the hazard switch. The hazard flasher is to the right of it.
The diagram is correct.
Re: Wiring Diagrams
« Reply #4 on: Sunday,July 25, 2021, 08:04:42 AM »
 Still wrong. Is the connection tie to the other wire .
Yes , the flashers are there.
Re: Wiring Diagrams
« Reply #5 on: Sunday,July 25, 2021, 08:12:53 AM »
Sorry, I don't understand!
Re: Wiring Diagrams
« Reply #6 on: Sunday,July 25, 2021, 08:29:40 AM »
  I’m talking about this connection. No problem it’s quite small.
Re: Wiring Diagrams
« Reply #7 on: Sunday,July 25, 2021, 09:18:36 AM »
     Your correct Roger!
    I went to the manual, it has the same cheesy connection into the green wire. I guess they were trying to save weight .  They have miles o unnecessary ground wires but another 12” in this case was saved.
   I noticed in the manual that these connections  are probably connectors   ( small square box)
 I’m not use to that symbol . I’ll put a notation down on legend.
« Last Edit: Sunday,July 25, 2021, 09:29:33 AM by dakazman »
Re: Wiring Diagrams
« Reply #8 on: Sunday,July 25, 2021, 12:28:15 PM »
  After getting past that hiccup,  I finished cleaning up the print for the TC Fed.
One of the best of the models.
 If anyone want this version PM me and I’ll send it to you.
Re: Wiring Diagrams
« Reply #9 on: Sunday,July 25, 2021, 12:33:17 PM »
Nice work, D’man! What did you use to draw that?
Re: Wiring Diagrams
« Reply #10 on: Sunday,July 25, 2021, 12:45:00 PM »
That’s the original
 Line work was done with an exclusive program .
Free with windows 10 called Paint 3D.
  BTW. Yes to GM Vette switches.
Re: Wiring Diagrams
« Reply #11 on: Sunday,July 25, 2021, 12:49:20 PM »
So you scanned the diagram and used paint 3D to alter it?
Re: Wiring Diagrams
« Reply #12 on: Sunday,July 25, 2021, 01:13:33 PM »
  No need to scan . just download your selected model from the home page ,lotus Joe posted . save the file to your desktop.
  open paint and select , Menu ,then Browse files. navigate to your desktop and select the downloaded file . click on open .
 have fun.
   remember on thing alway save your work  as a' SAVE AS' FIRST.  name it job 1or whatever you want .  then close out the program it will ask you to save work < SAY NO. no biggie if you don't, you'll just be changing the original file and have to download it again.
dave.
Re: Wiring Diagrams
« Reply #13 on: Sunday,July 25, 2021, 02:27:59 PM »
Of course! Thanks D’man!
Re: Wiring Diagrams
« Reply #14 on: Thursday,July 29, 2021, 09:38:41 AM »
   I noticed the Tcs windows switches are powered on a single aux feed lead where as the s2 have an independent feed to each side . Any drawback on being powered this way ? Is wire size different?
Can both sides run at the same time? Probably a little difficult to run both and drive at the same time.
 Also is there a reason for the switch to motor wires gown one on top and one on bottom the same color? Which one is up and down?
 Another observation on the TCSFed is what is called the Tunnel? With a light installed. Where exactly is this creature?
