Author Topic: Europa TCST  (Read 140051 times)
« Reply #885 on: Monday,October 16, 2023, 02:44:44 PM »
Great stuff, Turbo! is there a first noise event soon?
« Reply #886 on: Monday,October 16, 2023, 06:35:57 PM »
It seems there is always one more thing to do!
« Reply #887 on: Tuesday,October 17, 2023, 05:54:39 AM »
Looking great TF. Impressive work. What's the story on the green alternator belt? I don't think I've seen that before.
Offline kram350kram
« Reply #888 on: Tuesday,October 17, 2023, 07:25:45 AM »
 Based on what you are doing and what I have gotten into , I think we will always have “another” one more thing to do, even when done! What alternator are you using?
« Reply #889 on: Tuesday,October 17, 2023, 12:04:03 PM »
Not sure why the belt is green?
Alternator is a mini Denso.
« Reply #890 on: Monday,October 23, 2023, 02:14:40 PM »
My fourth grandkid(3rd grandson) showed up this past week so minimal Lotus work 😎
Drilled new hole in compressor housing to move water/methanol injector farther upstream to minimize bias going into intake manifold (that's not the injector). Using a Harley air filter until a later date to design something better (like everything on this project, not a bolt on, fabricobble involved)...decided to add a v-band flange to up-pipe as it is a nightmare to get to the turbo exhaust flange bolts and removing the pipe in the future to facilitate a starter change etc. will be a nightmare.... V-band on order
« Last Edit: Monday,October 23, 2023, 02:28:56 PM by TurboFource »
« Reply #891 on: Monday,October 23, 2023, 06:38:29 PM »
Congratulations on the new arrival. It’s always something special, precious memories that last a lifetime. Enjoy them.  Everything is now baby, baby, baby. At least for a couple months.😂
  It may give you time to relax and get a new plan of attack. Transitions from one task to the next before being completely finished and tested is a good thing for speeding up the completion of the total package.
« Reply #892 on: Monday,October 23, 2023, 06:53:24 PM »
Congratulations grandpa!! Congratulations to mom and dad too, of course!
« Reply #893 on: Wednesday,October 25, 2023, 03:44:16 PM »
I brought TCST home three years ago yesterday..... I need to speed it up several notches!
I have made progress.... It is helpful to go through all the pics because when you look at it every day you wonder what you have accomplished ???
« Reply #894 on: Thursday,October 26, 2023, 06:36:03 AM »
You've come a long way, baby. :beerchug:
« Reply #895 on: Monday,October 30, 2023, 12:59:38 PM »
Added v-band clamp to up-pipe, throttle cable pulley needed more pull wrap so I added piece of bent tubing that I split open. Working  on adding breather tubing to air cleaner base.
« Reply #896 on: Monday,November 06, 2023, 10:27:06 AM »
Exhaust can now be assembled with body on the chassis  :) Finished air filter setup for breather etc.
Working a new throttle cable….boy is it fun to get that little cotter pin out of it way in there , glad the doors are still off !
« Reply #897 on: Monday,November 06, 2023, 10:48:13 AM »
Looking really good!  :beerchug:
« Reply #898 on: Friday,November 10, 2023, 01:06:03 PM »
High dollar throttle cable bracket...a piece of brake tubing to guide the cable and welded to a piece of scrap I hacked up ... needed to plug a 1/8npt hole in turbo that conveniently lined up with throttle cable position so I drilled and tapped a npt plug to hold the bracket (simplify....) Replaced inner cable and made new end out of 1/4” bolt shank I drilled a 1/16” hole through and soldered it.
« Reply #899 on: Monday,November 13, 2023, 12:48:31 PM »
Made a new battery hold down and did a few little things that needed done.
