Author Topic: Europa TCST  (Read 157756 times)
« Reply #450 on: Monday,January 17, 2022, 01:01:42 PM »
No going back now  ;)
I cut the ends off my anti-roll bar and sanded/filed the end round so I could slide
the adjustable end link clamps on that I made. Painted the bar and started cleaning up
my rear Koni's so I can take them apart.
Offline tedtaylor
    • TaylorMadeClassicCars
« Reply #451 on: Monday,January 17, 2022, 01:16:56 PM »
if you decide to go back to original, i have one i'm selling for $80
http://www.taylormadeclassiccars.com/images/IMG_3953.JPG
TED
'13 Evora S
« Reply #452 on: Thursday,January 20, 2022, 05:11:18 PM »
Adjustable anti-roll bar end link....
(I end up moving lower mount position...and going to double shear on the top link mount)
« Last Edit: Wednesday,November 29, 2023, 06:17:56 PM by TurboFource »
« Reply #453 on: Monday,January 24, 2022, 01:20:31 PM »
The cleaning, sanding/scrubbing, painting seems never ending.....some more parts done :)
Wrestling the u-joints out with a c-clamp ..... Lot's of torture usually severe ..... I miss having access to an arbor press....
« Reply #454 on: Monday,January 24, 2022, 01:39:26 PM »
Looking good! I've always used a vice for u-joints.
« Reply #455 on: Monday,January 24, 2022, 02:15:10 PM »
You can also use a soft face hammer.  I use a lead hammer.
« Reply #456 on: Monday,January 24, 2022, 03:07:24 PM »
I like the sway bar. Adjustable is nice. Did you mount it off the upper control arm bolt?
Offline cwtech
« Reply #457 on: Monday,January 24, 2022, 05:07:57 PM »
The Heim joints and adjuster are in tension/compression, so they should be OK.
With the upper and lower bolts in single-shear, will that become an issue?
« Reply #458 on: Monday,January 24, 2022, 06:03:18 PM »
Clifton, yes mounted with upper control arm bolt.
CW….I will keep an eye on them….they are grade 8 and 3/8”
« Last Edit: Monday,January 24, 2022, 06:07:14 PM by TurboFource »
Offline brucelotus26r
« Reply #459 on: Tuesday,January 25, 2022, 05:00:11 PM »
Glen broke his shock on his Europa on the way home from Don Butler's when we hit a place in the road where they had 1 1/2  dump  for repaving.
« Reply #460 on: Tuesday,January 25, 2022, 05:35:43 PM »
Low profile tires exacerbate the issue.  I run 175/70 series and not a scratch.
Offline Fotog
  • 72 Twin Cam
« Reply #461 on: Tuesday,January 25, 2022, 06:44:03 PM »
It looks like my car, run with normal sized tires, was used for off-road rally racing.  Pretty much everything underneath has some evidence of off-road work, and the sway-bar bushing thingies (just what are they called?) are definitely flattened.
« Reply #462 on: Monday,January 31, 2022, 02:18:24 PM »
This week:
-Finished removing u-joints and degreased the half-shafts
-Painted rear uprights
-Wire brushed/sanded trailing arms (used scotch Brite stapled to a board to do inside) and degreased in prep for painting
-Rear Koni's getting soaked with penetrating oil for a week so I can take them apart
« Reply #463 on: Monday,January 31, 2022, 04:36:47 PM »
Nice work turbo, I don’t regret getting past that assembly. Keep up the pace .👍👍your doing great.
« Reply #464 on: Monday,January 31, 2022, 05:13:24 PM »
What D'man said! You're making great progress!  :beerchug:
