Author Topic: 1970 s2 0453R Reassembly  (Read 298825 times)
« Reply #2025 on: Thursday,October 05, 2023, 12:28:12 PM »
DMan,
Any luck?
Here is one a guy made for a Europa S2 $2000 Challenge car .... https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/the-grm-free-lotus-europa-2gr-v6-swap-2000-challenge-car/186375/page22/ (Purists don't look....)
« Reply #2026 on: Thursday,October 05, 2023, 01:11:10 PM »
DMan
I reached out to them, they will make them.
PM me your number and I will send you the text conversation I had with them…..
« Reply #2027 on: Thursday,October 05, 2023, 02:26:23 PM »
I would think a plexiglass windshield would get scratched pretty easily and often. I think that (some?) states have relaxed their rules for film on the windshield and you might be able to find a film that blocks UV and is scratch resistant. That would be cooler and cheaper and maybe easier...
« Reply #2028 on: Thursday,October 05, 2023, 06:16:30 PM »
These are coated. It says you can use wipers when necessary but they shed water better than glass and it says 250 times stronger than glass and half the weight…I may get one ….
« Last Edit: Thursday,October 05, 2023, 06:37:59 PM by TurboFource »
« Reply #2029 on: Friday,October 06, 2023, 03:19:20 PM »
 Turbo,
   I whet down to a local store that carried acrylic sheets. I'm not impressed with the flexibly I felt. maybe with the bends and curves it will stiffen up a bit. I just can't imagine wipers going at 70 mph and the windscreen flexing.
   They were out of 5.5 mm so I will go back and do a feel test on a good 1/4-inch sheet. It looked like 3/16"'for acrylic. $106 for a piece that can be formed.  At 600$ plus shipping it seems that the glass would be a better choice. I'm still open for more discussion about this subject.
  the yellowing and crazing is another problem as is the air bubbles in the plastic.
« Reply #2030 on: Saturday,October 07, 2023, 03:57:07 AM »
The ones are at racingsheilds are optically clear polycarbonate so I don’t think there are bubbles etc.,
They also make windshields for farm and construction equipment that are in the sun their whole lives so I wouldn’t think UV is an issue  :confused:
« Reply #2031 on: Sunday,October 08, 2023, 03:16:04 PM »
My experience with clear acrylic sheet tells me that it can be brittle.  We bought some for a treehouse for the kids, and managed to crack it.  Polycarbonate, on the other hand, is nearly bombproof.
« Reply #2032 on: Tuesday,October 10, 2023, 05:25:32 AM »
  Thanks guys,
  Been a little busy on other items. I just need a bit more information and do some more research.
 I started a a thread on clutch mod for S2 336 gearbox.
« Reply #2033 on: Tuesday,October 10, 2023, 05:52:37 PM »
  Thanks turbo for all your help, but I decided to go with the tried and true glass screen.
« Reply #2034 on: Tuesday,October 10, 2023, 06:09:51 PM »
No problem!
« Reply #2035 on: Thursday,November 09, 2023, 03:08:23 PM »
Back to my home thread, and reporting on my A/C system . The final hoses and fittings came in today so whenever I get to swedging the bead lock fittings and run the hoses. My route is thru the front boot into wheel well , down into the door sill area and to to other components.
« Last Edit: Thursday,November 09, 2023, 04:49:22 PM by dakazman »
« Reply #2036 on: Monday,November 20, 2023, 05:12:41 PM »
  My fittings and hoses arrived so I started the run . After cutting a pathway to to fender well I made a plate for protecting the glass from the fatigue of the hoses and protecting the hoses from chafing.
 The 14 foot run of the hoses needed to be run together so I came up with using a bicycle tire tube
To hold them in the run. Today I finished adding some fiberglass between the inner fender well and the front storage bay. Now to do the run.
« Reply #2037 on: Monday,November 20, 2023, 05:36:47 PM »
That will feel really cool next summer when you’re driving down the road. You are going to have it driving by next summer, right?
« Reply #2038 on: Monday,November 20, 2023, 06:19:58 PM »
   I’m hooking up these lines and doing a leak check, then putting the interior back together.
The windscreen should be in soon from RD but then the wait on delivery down here.
 I want to make a February 4 car show. This week is my downfall, anniversary, my wife’s and my bDays, thanksgiving. Then get Christmas up and running.
  Bleeding Brakes, , bleed radiator,  then polishing it up again. 😂 then a small problem with my ac control of the cabin fan. I just get hi and low, but I’m working on it but it’s easier with dash out.
   Then I have to build a picture frame, and rebuild a window, polish out the hood of the elky and register and license it, along with registration on the lotus .
  So 3 of my cars will get antique plates since they go by my birthday for renewal. That should also cut my insurance costs a little.
D’man
« Reply #2039 on: Monday,November 20, 2023, 06:24:21 PM »
Sounds like a full schedule! Stay focused!  :)
