Author Topic: 1970 s2 0453R Reassembly  (Read 297813 times)
« Reply #1590 on: Wednesday,December 22, 2021, 04:20:44 PM »
  I may be able to increase the pulley another 1” max . I don’t have that notched type belt ,  my v belt is solid .  However the belt that I have in there for plan c is now to short, so I’ll be running out for another.
  John, if you have time can you give me a dimension below your carbs and frame. Reason, I need about 4 1/2 - 5” to place a compressor their on the cross flow using the same front bracket.
If I don’t hav the room there I’ll try fitting it below the header but on top of water pipe.
  If all that fails I won’t use the extended crankshaft on my cross flow.
  On another project I polished up a tc bell housing and a few other items . while I was at it I found a faster way to bring out the mirror using 3M Scotch-Brite Roloc Surface Conditioning Disc, and green/ brown rouge’s. These pieces shined up after 400 grit. See before pics . I have a new aluminum sealer that was suggested long ago.  My antique van has 4 wheels that really need a makeover.
« Reply #1591 on: Thursday,December 23, 2021, 07:22:54 AM »
"John, if you have time can you give me a dimension below your carbs and frame. Reason, I need about 4 1/2 - 5” to place a compressor their on the cross flow using the same front bracket. "
Mine is packed with pipes, hoses, etc but I think there's close to 6" clearance.
« Reply #1592 on: Thursday,December 23, 2021, 10:58:44 AM »
  Thanks John , it’s going to be tight for sure on a cross flow with dual webers and the air box.
 I guess I should have used the quote feature. It helps clarify the question.
    On another note , I thought I had the seals for the liners with a gasket set but it only had the paper shims. The liners had the thin rubber shims. I have another gasket set coming from Serbia since early November so I’m hoping they will be in that set. Everything on my 843 valves , crank , cam and pistons are all original specs.  That’s the holdup for now.
« Reply #1593 on: Monday,December 27, 2021, 04:37:33 PM »
  I hope everyone had a great holiday. I have gained at least 10 pounds. 😁 but I enjoyed every bit of butter turkey bits and my choice of several desserts. Not to mention a little overindulgence in the finer liquid refreshments.
   I did manage to get started cleaning up garage a bit , setting up the crossflow on the build stand . As usual I couldn’t resist .🙈😎 I’m just going to enjoy looking at it for probably a year , so I posted a few pics of this build. My engine gasket set is due on Friday. Hopefully the liner seals will be included.
  Happy New Year,
« Reply #1594 on: Monday,December 27, 2021, 06:17:55 PM »
That is going to be a beautiful engine!
« Reply #1595 on: Monday,December 27, 2021, 07:07:20 PM »
  Thanks Turbo🙏
Offline S2Zetec54
« Reply #1596 on: Tuesday,December 28, 2021, 04:03:55 AM »
That’s an amazing finish. Hats off to you
« Reply #1597 on: Thursday,December 30, 2021, 07:12:38 PM »
 Thanks S2 ,
  I’am developing mirror madness a bit using some new tooling and techniques. All most at a mirror shine now .  I’ll have a little more time to work on it since the gasket set I purchased did not have the liner seals included. 🙁
  My belt system for the ac is installed, behind firewall plain. I’ll do a few more tweaks to the alignment of the pulleys and a few other items before closing.
   I’ll also get to start assembly of the harness as soon as I pack up the holidays, since my garage is at full capacity.
« Reply #1598 on: Friday,December 31, 2021, 03:31:04 AM »
Do you preserve/protect the finish?  If so, what do you use?
I have been using VHT clear engine paint, which seems to hold up and not yellow.
« Reply #1599 on: Friday,December 31, 2021, 06:15:17 AM »
  Yes Pfreen,
  I used the VHT on my daughters motorcycle casings and it held up nicely. She sold the bike , after all that work , but at a profit.
  I also use spray max 1k on a few items , headlight lenses and side view mirrors. I’ll attempt to do my vans wheels after I clean them up a bit.
  The center pictured clear is everbrite, I will be using on this motor. It has good reviews.
Offline kram350kram
« Reply #1600 on: Friday,December 31, 2021, 06:38:03 AM »
Second the Protect-o-clear from Everbrite. I used on polished aluminum motorcycle cases and has held up for 10 years. Gas and oil seem not to effect it.
« Reply #1601 on: Friday,December 31, 2021, 10:14:05 AM »
   Kram,
   Any noticeable yellowing when hot? The sales people couldn’t give me a straight answer on that.
I imagine you ran your bike in 10 years 😂. Thanks , after all this work I don’t want to powder blast it later.
« Reply #1602 on: Saturday,January 01, 2022, 04:09:57 PM »
  Put away some of my outside Christmas lights and help a neighbor with a few ladder jobs he thought he could do .  I dug out some scrap metal I had laying around while cleaning the shed😕. I got right on  cutting it up for an engine stand I saw somewhere. It didn’t help that the outside temps in the sun went to 110f 🙁
  I cut out a few aluminum plates needed for the head and fuel pump. Basically a good start of a new year. 😃
« Reply #1603 on: Sunday,January 02, 2022, 05:14:58 PM »
  Just an update ,
   A/C belt routing and clearances. I feel good with this plan, so it’s time to move along to the testing.?
One good thing is now I can crank the engine over the set the valve clearance by the crankshaft.
   Engine stand front view , now I need to place the legs , probably just welding after cutting a 45 degree on all joints. Welding the bar to the motor mount plate will be done after attaching the housing and gearbox . Right now it slides through.
 Fuel pump plate and a head sensor cover cut out.
Offline kram350kram
« Reply #1604 on: Sunday,January 02, 2022, 05:50:34 PM »
No yellowing or peeling at all. I used it on 2-stroke cases and they do get pretty hot. I polished them, wiped down with acetone and sprayed two coats. No weather corrosion and really no scratching from my boots.
