Author Topic: 1970 s2 0453R Reassembly  (Read 297813 times)
« Reply #360 on: Tuesday,September 11, 2018, 10:41:48 AM »
Progress ...at last!
Sanded , rubbed out with paste wax and buffed. Just the test inserts but dash is sanded and rubbed.
    Ps, a Japanese owners car in white😀
« Reply #361 on: Tuesday,September 11, 2018, 04:34:56 PM »
You do great work Dakazman! Too bad we don’t live closer to each other.....
« Reply #362 on: Tuesday,September 11, 2018, 05:33:58 PM »
G'day, Dakazman,
Are you going to paint the edges of the switch holes dark brown like the factory?
The edge of the ply will be visible otherwise.
Cheers,
Gavin
« Reply #363 on: Wednesday,September 12, 2018, 02:18:52 AM »
 Hey Gavin,
   Thanks for telling me what color the edges were, I almost did black👍👍,which I thought would be to much of a contrast. Thanks again
« Reply #364 on: Wednesday,September 12, 2018, 03:31:47 AM »
Certified, thank you!
   So many details to research, parts that I thought I could just throw back in turn out to need some attention. Trying to stay focused and not doing modifications to a point. Still to humid and hot to paint even small parts . Another month or two and that should change.
« Reply #365 on: Wednesday,September 12, 2018, 07:46:04 AM »
I almost did black . .
I did mine black because I had the pigment on hand and couldn't be fagged chasing down some brown.
Ooops . . :))
« Reply #366 on: Thursday,September 13, 2018, 07:56:58 AM »
Progression of door cards, door pulls in 5518 stainless and mold of tach/speedo.
« Reply #367 on: Thursday,September 13, 2018, 09:42:40 AM »
That's going to look nice!
« Reply #368 on: Tuesday,September 18, 2018, 03:22:55 PM »
 More glass work on these two items , then a mold. The original plastic is way to flimsy so I made it out of glass and can paint or apply a covering . I’m thinking gloss black on entire console.😀
« Reply #369 on: Tuesday,September 18, 2018, 06:17:37 PM »
Looks good, Dman! Since you have molds, you can make $$ making them for people!  :)
« Reply #370 on: Sunday,October 07, 2018, 09:58:31 AM »
Still just puttering around this week working on the molds ,steering column, w/w closeouts but building the circuit board was fun. Also picked up a manifold for my cross flow engine.😀
« Reply #371 on: Tuesday,October 09, 2018, 05:00:44 PM »
 Steering column and turn switch coming along with the turn switch passing all tests.  The dash was finally painted black on the inside edge of glove box and speedo/ tach. A few other firewall plates were also made with stainless steel plate.
« Reply #372 on: Friday,October 19, 2018, 01:30:13 PM »
Rebuilding /fabricating numerous parts and finally hung the wiring harness.
Routed and untangled as I secured it to a mock-up board . Next I will transpose the breakouts in the runs and unwrap the rest of the harness, check wire by wire with schematic and replace runs that are inconsistent.
  Add a few extras for future use also afterward . Starting to notice a drop in the humidity so painting season will soon start. I’m glad I missed my deadline because the clear coat on my car really constricted and shows some hi and lows in the glass fibers. The engine cover also needs repairs bc I stored it upside down for about two weeks and the support structure bent upwards , resulting in seeing a big x from the top side.
« Reply #373 on: Friday,October 19, 2018, 01:34:40 PM »
Do yourself a favour and fit a reduction gear starter.  Works much, much better.
« Reply #374 on: Friday,October 19, 2018, 02:00:09 PM »
I agree with JB. The only disadvantage is that the gear reduction turns the motor much slower getting oil pressure from cranking the starter takes longer. That's a minor point, though.
