Author Topic: Zetec Conversion Questions  (Read 10045 times)
Offline RoddyMac
Re: Zetec Conversion Questions
« Reply #30 on: Tuesday,November 22, 2022, 06:55:42 AM »
Both are based on the Ford 105E block.
Time to be an anorak, that's not quite correct.  The Zeta engine shares the bellhousing bolt pattern as a 105E block, but the Zeta (or Zetec) was based on the CVH block architecture.
« Reply #31 on: Monday,January 02, 2023, 08:45:12 AM »
Well, time has come and I've removed the engine and transaxle from the TC, and have purchased a '01 Zetec blacktop engine.
While I'm at it, the body will come off for a frame inspection. Coolant tubes replaced, and I'm sure other things will pop up.
In preparation of conversion I've got some questions. I'm sure I'll be back with more. (hence this thread)
Sorry for coming in late on this thread - I must admit though I am quite envious.  ;D
Out of interest - what chassis is your car running - original or other?
« Reply #32 on: Tuesday,January 03, 2023, 08:34:11 AM »
Are we re-inventing the wheel here though? Didn't Chuck Nukem cover all of this?  http://www.lotuseuropa.org/LotusForum/index.php?topic=4158.0
« Reply #33 on: Wednesday,January 04, 2023, 02:23:40 PM »
I used the silver top Zetec and it bolted up to the gear box without issue. However I did have to make new motor mounts.
