Author Topic: Fuel pump europa s2  (Read 899 times)
Offline rawiz
Fuel pump europa s2
« on: Wednesday,May 21, 2025, 09:20:47 AM »
Hello. Just replacing perished fuel pipes on my working lotus europa s2. Has anyone seen this arrangement of connections to the fuel pump before please? One line is blanked off (a return line perhaps?), is this the wrong fuel pump but a known OK modification cos original mechanical pumps unobtanium or something? Thank you.
Offline kapps
Re: Fuel pump europa s2
« Reply #1 on: Wednesday,May 21, 2025, 04:21:23 PM »
It’s been a long time since I’ve looked at a stock Renault fuel pump but one line should be going to the carb and the other is the return back to the tank. The return line should be going back to the bulk head fitting on the front of the fuel tank that is also the level sender. It’s possible that a PO replaced the sender with one that does not have a return nipple.
S2 0705R
Offline 314159td
« Reply #2 on: Wednesday,May 21, 2025, 10:33:12 PM »
That's an original pump, with the little clamping bar and screw holding the top down. There's a pickup line at the base of the tank, then a return thru the tank sender and supply to the carb on the same outlet tee.
http://lotus-europa.com/manuals/s2parts/l/index.htm
Offline rawiz
« Reply #3 on: Sunday,June 01, 2025, 07:02:04 AM »
Thank you for the info. Is this likely to cause pump issues, etc, if no return?
Offline rawiz
« Reply #4 on: Sunday,June 01, 2025, 07:15:28 AM »
I’ll get a photo of the fuel tank later.
Offline rawiz
« Reply #5 on: Monday,June 02, 2025, 02:44:55 AM »
Fuel tank connections do look different
Offline rawiz
« Reply #6 on: Monday,June 02, 2025, 02:46:15 AM »
And
Offline kapps
« Reply #7 on: Monday,June 02, 2025, 06:36:33 PM »
There should be a nipple on the level sender next to the electrical connections where the return line goes back to the tank. When I was searching for a new sender many years ago, I recall options for senders with and without the return line port. A low pressure electric pump does not need a return. I really don’t know how the stock pump works without one.
S2 0705R
Offline rawiz
« Reply #8 on: Wednesday,June 04, 2025, 03:43:35 PM »
Hmmm this new s2 fuel tank with sender from approved historic lotus spares appears to have a return nozzle hole welded on next to sender! An option then.
https://www.sjsportscars.com/parts-and-accessories/SJ046L0001.htm
Offline rawiz
« Reply #9 on: Wednesday,June 11, 2025, 05:13:01 AM »
Having a look for fuel senders with the return nozzle but maybe no longer available. Mechanic suggesting potentially welding in a nozzle to the (aluminum) fuel tank on the side, insitu.
Offline rawiz
« Reply #10 on: Wednesday,June 11, 2025, 11:50:51 AM »
Ha I’d missed this related past discussion on this kind of topic!
https://www.lotuseuropa.org/LotusForum/index.php?topic=1400.0
