Author Topic: Yellow 1973 Europa Rotary 2nd time on BaT  (Read 653 times)
Offline Dreamer
Living life on the edge. Less crowded, better view!
Offline SwiftDB4
Re: Yellow 1973 Europa Rotary 2nd time on BaT
« Reply #1 on: Monday,May 19, 2025, 07:45:31 AM »
Looks like a lot of good engineering, but 17" wheels give it a cartoon appearance.
« Reply #2 on: Monday,May 19, 2025, 10:15:01 AM »
I don't want to pollute his sale but.... OBD shows zero warmups since dtc's cleared. It was jusy cleared. He should show readiness but it would say it's not. Who knows why the dtc was cleared and what it is but with zero warmups, it likely comes back quick. Suspect as F though. FWIW, you can remove dtc's from factory ecu's. I had canister and trans dtc's removed.
Cool car but seems to lack a/c and considering the amount of work and weight I don't see why it doesn't have it.
