Early liners (all original Europa engines) use paper shims under the liner to adjust liner height and seal the bottom of the liner. Later liners used o-rings. You can modify an early block totake later liners but it will require expert machining of the block and liners. Not worth the triuble and expense as the proper parts are available for both applications and both applications work well if assembled properly.
