Author Topic: Rear Adjustable Lower Links  (Read 741 times)
Offline My S1
Re: Rear Adjustable Lower Links
« Reply #15 on: Friday,May 09, 2025, 12:57:27 PM »
Excellent tip on the AN bolts.  I have not taken mine apart yet but I would not doubt that the threads are grinding away at the uprights.  The pictures that you folks have provided clearly show that I need "high misalignment " ends and spacers.
« Reply #16 on: Friday,May 09, 2025, 03:01:19 PM »
If you have a civil air port with a parts counter, that would probably be the best place to get AN hardware. You can also get it at fleabay. Usually that would come in quantity - i.e. 10 or more pieces. For onsies twosies, Aircraft Spruce (https://www.aircraftspruce.com/menus/ha/index.html) is a good place to look. Occasionally, Pegasus Auto Racing Supplies has a better price but not usually.
Here is an AN bolt chart that gives dimensions (grip lengths, total lengths, etc):https://skybolt.com/wp-content/uploads/2017/07/Catalog-AN-MS-Hardware.pdf
Offline My S1
« Reply #17 on: Friday,May 09, 2025, 03:23:16 PM »
Nice chart for the files, thanks BDA.  I found some very sweet high misalignment ends from Rod Ends Supply.
https://rodendsupply.com/shop/high-misalignment-teflon-lined-rod-ends/?attribute_size=1%2F2%22Bore+5%2F8-18+Thread&attribute_thread-direction=Left&_gl=1*88q76h*_up*MQ..&gclid=EAIaIQobChMIpvr70vCUjQMVah6tBh2bEyaLEAAYAiAAEgKBS_D_BwE&gbraid=0AAAAAqOLSumdgQrZ3GYTSU_bf6f1s3FgR
I have never used theirs before; my preference has always been the Chassis Shop, but I might go with these.  Unfortunately they don't offer rubber boots or caps and it might be difficult to find them to fit due to the width of the bearing.
« Reply #18 on: Friday,May 09, 2025, 04:46:46 PM »
Here are some boots (https://www.ebay.com/itm/133665951454).
Be aware that getting high misalignment rod ends will not mean that you won't need spacers for the inner attachment.
A thought: It would probably be best to get spacers like these (https://www.ebay.com/itm/271116858786) to go against the upright. I think something with a broad base on it works better against the aluminum of the upright.
Offline My S1
« Reply #19 on: Friday,May 09, 2025, 06:54:34 PM »
Thanks for the tip.  I'll be machining the spacers myself.  I wonder about boots though...do you think they would trap condensation or am I getting too deep into it again...
« Reply #20 on: Friday,May 09, 2025, 07:04:43 PM »
Condensation is not what you’re worried about. It’s road grit.
I don’t think anybody’s mentioned yet. You want the Teflon lined rod ends. I don’t think the Teflon lined rod ends have balls that can come out but if some do, you don’t want them.
Offline bjthomp
« Reply #21 on: Saturday,May 10, 2025, 09:36:08 AM »
Here's a spec sheet showing the different grades of rod ends.  Rather than teflon, I believe Sphereco offers a lubricated type that uses carbon fiber.
