Author Topic: Renault Crank and Rods  (Read 852 times)
Offline loudoun
« on: Wednesday,May 07, 2025, 07:24:41 PM »
All, forgive my ignorance here. I recently picked up a basket case S2 with a non Lotus spec Renault motor. The PO purchased a Lotus spec cam and pistons from R&D for a rebuild. However, before I reassemble, does the Lotus spec Renault use a standard Renault R16 crank and rods?
Re: Renault Crank and Rods
« Reply #1 on: Wednesday,May 07, 2025, 07:26:31 PM »
Short answer: yes.
« Reply #2 on: Friday,May 09, 2025, 02:29:11 PM »
 Loudoun,
   Welcome to the Renault side.\
  Here is some good reading for you.
 https://www.lotuseuropa.org/LotusForum/index.php?topic=1748.0
Offline loudoun
« Reply #3 on: Sunday,May 11, 2025, 02:29:32 PM »
Thank you to you both. I have the crank at the machine shop to get balanced and polished. Do you think there is any issue with reusing old rods, or are there sources for new?
« Reply #4 on: Sunday,May 11, 2025, 05:20:53 PM »
Renault16shop has many parts and then some.
« Reply #5 on: Sunday,May 11, 2025, 05:37:18 PM »
I have a set of later/stronger type rods I would let go cheap.
« Reply #6 on: Monday,May 12, 2025, 07:45:50 AM »
Rods can be reused bit need to be checked by a good machine shop.  Very common to have the big ends resized.
« Reply #7 on: Monday,May 12, 2025, 03:46:52 PM »
The Alpine A110 parts can also be used but have a higher price.
« Reply #8 on: Monday,May 12, 2025, 08:52:35 PM »
I bought some hi-zoot rods out of Australia.  Had minor clearance issues, just the usual fettling issues when fitting HP parts.
Make a difference?
For a stock-ish engine?  No.  Just get your old rods checked properly and straightened, resized, and/or rebushed as required.
For a warmed up engine that is going to live in the 5k to 7k range?  It is one of the usual mods to strengthen the bottom end.  It won’t make any more power but it will be less likely to put a rod through the block at very high rpm.
« Reply #9 on: Monday,May 12, 2025, 09:57:31 PM »
Just a note here.
The higher HP Alpine/Gordini engines used 21mm fully floating gudgeon pins. (pic below)
The cooking varieties of the Renault R16 engines used 20mm press fit pins and a bolt/nut fastener for the bearing cap as did the Lotus versions.
