Author Topic: How to remove center lower manifold nuts S2?  (Read 565 times)
« on: Monday,May 05, 2025, 09:28:41 PM »
I am baffled as to how the center lower manifold nuts are removed on an S2 wedge engine.
I cannot get a socket or a wrench to fit!
Even after removing the starter for access from below.
I hope a header upgrade will make reassembly simpler.
But for now the issue is how to get the manifolds off?
Offline 314159td
Re: How to remove center lower manifold nuts S2?
« Reply #1 on: Tuesday,May 06, 2025, 04:24:41 PM »
You have the cast iron combined intake/exhaust manifold, right?
Mine wouldn't fit an socket in a straight shot, I think I used those sockets with an integrated u-joint, 3/8" drive.
Offline kapps
« Reply #2 on: Tuesday,May 06, 2025, 05:20:44 PM »
I recall that I also used a u-joint socket to remove them.
S2 0705R
« Reply #3 on: Tuesday,May 06, 2025, 09:13:04 PM »
I have an aluminum Warnford single Dellorto conversion and the cast iron exhast.
I cannot see how they got the center lower nuts tight.
I cannot get to them from any direction.
There is no room for any sort of socket or a wrench.
All I can think of is to grind a box end until it is very thin.
« Reply #4 on: Wednesday,May 07, 2025, 03:51:12 AM »
Can you post a pic?
« Reply #5 on: Thursday,May 08, 2025, 08:43:36 PM »
Finally got them after ruining a 13mm socket.
Ground it short and reduced diameter a LOT!
Even with that it barely got done.
Luckily the nuts were brass and did not stick.
I hope the new header exhaust will be much easier.
Offline kram350kram
« Reply #6 on: Friday,May 09, 2025, 06:44:50 AM »
On reinstall maybe use a jet nut?
« Reply #7 on: Friday,May 09, 2025, 09:52:13 PM »
The cast exhaust really has no space for a socket or wrench.
I did note that they were not as tight as expected.
I suspect a very thin wall 1/4" drive 13mm and swivel might have worked if I had them.
Just one more reason to use a tube exhaust when going back together.
I would also say to always use brass too.
« Reply #8 on: Saturday,May 10, 2025, 05:46:57 AM »
Offline kapps
« Reply #9 on: Saturday,May 10, 2025, 01:25:27 PM »
I hated those nuts so much that I took some large (1/2” dia IIRC) shoulder bolts, cut them to length, drilled and tapped the end, and turned the OD of the head down for clearance. I basically made closed end manifold nuts that I can get to with an Allen hex socket. Add some copper anti-seize to the threads and never use a ball driver because if the hex ever rounds out, it’s going to be a very bad day.
S2 0705R
« Reply #10 on: Saturday,May 10, 2025, 04:58:16 PM »
I like that.
I will also probably do something custom when it is time for reassembly.
