Author Topic: US source for S2 dash? (Looks like it will be Me!)  (Read 4181 times)
Offline MAK
Re: US source for S2 dash? (Looks like it will be Me!)
« Reply #30 on: Sunday,April 20, 2025, 05:26:33 AM »
Old Dash Pictures - 46" wide
image 8311,12,13 & 15 Front
image 8316,17,18         Back
image 8324, 27             Damage right hand (passenger side)
There are some small areas on the back where a single layer of the plywood is missing, should you require more just PM me.
« Last Edit: Sunday,April 20, 2025, 05:34:14 AM by MAK »
"The best to you each morning"
Offline Gary t
« Reply #31 on: Sunday,April 20, 2025, 07:01:48 AM »
I have a s2 model 54 panel that is good except  the radio hole I could trace if that would help.
Gary
Gary Toffelmire
54/1173
« Reply #32 on: Sunday,April 20, 2025, 09:59:14 AM »
54 is different than 65?
I have been setting up my woodworking space.
Need to get the body off the red car ASAP so that I may take the dash out to re-Veneer.
I will post progress as it happens.
Offline Gary t
« Reply #33 on: Monday,April 21, 2025, 06:42:22 AM »
I think hazard switch and maybe ignition switch.
Gary Toffelmire
54/1173
« Reply #34 on: Monday,April 21, 2025, 06:04:08 PM »
Seems odd that an S2 dash would have an ignition switch hole when the ignition is on the column.
Maybe a good place for a USB port?
Offline Gary t
« Reply #35 on: Tuesday,April 22, 2025, 06:24:59 AM »
54s have a switch on the panel away over to the right not on the column
Gary Toffelmire
54/1173
« Reply #36 on: Tuesday,April 22, 2025, 11:14:05 AM »
If you look at the dash...it's symmetrical, and depends on where they put the filler pieces for LHD vs RHD.   The unused hole for LHDs frequently had a cigar lighter in the hole on the passenger side (which is, if you flipped the dash around and moved the filler pieces to the now rear side, it would be where the washer switch went...).  The locking column was an add-on to satisfy the bureaucrats; the ignition switch wiring actually ended up on (for us in the LHD world) the passenger side, and there was a jumper harness that linked the wiring from the column to the passenger side of the harness.
I just, in 693R, removed the locking switch on the column and jumper harness and put the ignition switch where it was intended to live on the passenger side.  I figured that 1) no one would want the car and the locking column switch was one more thing to go bad and 2) it eliminated an extra set of contacts on the ends of the jumper harness, simplifying what was in back of the dash.
It also looked cleaner, to my eyes anyway.
« Last Edit: Tuesday,April 22, 2025, 11:17:58 AM by Bryan Boyle »
« Reply #37 on: Sunday,May 04, 2025, 08:29:57 PM »
I now have a TC dash thanks to the kindness of another member.
Surprised to find so few differences.
« Reply #38 on: Tuesday,May 13, 2025, 08:50:15 PM »
I expect to have my quote for local Lazer cut dash blanks in the morning.
Local is important as it avoids one shipping expense, I will just go pick them up.
The first question to pop up is, how many S2 vs TC in this first batch?
I need two S2 for myself, so thinking four of each?
The fun is going to be the laminate faces.
But I do have the vacuum bag and other supplies on hand.
Anyone interested let me know.
I expect to beat the currently available unit prices substantially.
Offline MAK
« Reply #39 on: Wednesday,May 14, 2025, 03:26:12 AM »
Good luck, hope the quote is reasonable. please post pics when you get it back
« Reply #40 on: Wednesday,May 14, 2025, 06:08:36 AM »
Richard, I'll be interested in two TC dashes.
