Author Topic: 1970 s2 0453R - A new Beginning  (Read 18838 times)
Re: 1970 s2 0453R - A new Beginning
« Reply #90 on: Wednesday,November 13, 2024, 02:50:16 PM »
Finally an S1 project that makes what mine was look pretty good ;-)
Those are seats are not stock.  The S1 has two cushions that fit into molded recesses.  I could go on, for example the auto trans (?!)...
   JB, :FUNNY: you're my guide here and maybe Serge. You're the only two I know of. Hopefully I'll be bringing it here this week. I dont want to overburden the son to go through the garage and attic.
   This car is just a donor car. Title paperwork was ignored by both seller and buyer.  The frame is eaten away as is the body. I'm bringing home all the parts the owner collected. I told him I'll pay him for some of his parts when sold.., I'll try to make a mold of some of the glass pieces, console and aft tray.
« Last Edit: Wednesday,November 13, 2024, 02:53:06 PM by dakazman »
« Reply #91 on: Wednesday,November 13, 2024, 05:05:14 PM »
 Here are some other items I dug out. The gearbox has a tag but I didn’t yet unbend it, but the shifter showed reverse opposite of my 336.  Working on a trailer for picking up the rest. Hopefully some bumpers are side and front windows and another taillight assembly.
« Reply #92 on: Friday,November 15, 2024, 02:19:55 AM »
  Worked a deal with a friend for the use of his trailer.
    Repair the holes in roof.
    Fix wiring .
    Clean out dead possums.
    Pressure wash
  Can’t be to bad… it should be big enough to recover the S1.
« Reply #93 on: Friday,November 15, 2024, 03:26:16 AM »
I think it will fit in there!
« Reply #94 on: Saturday,December 28, 2024, 07:13:52 PM »
  I’m getting ready for the Xke return so I played Tetris and moved the Europa into its new home.
 I am still working on her, buying all the materials I need for the engine compartment lift cylinders.
« Reply #96 on: Tuesday,December 31, 2024, 10:13:39 AM »
 Thanks Jim, Pfreen gave me the second link, now I’ll compare the two. I all ready picked up a set of gas struts and ends. Couldn’t find round 4’ stock so I ended up with square stock. No biggie.
 I have until feb 4 for another car show to install it and fix my slight brake drag probably induced by my overcompensating the pedal height.
« Reply #97 on: Sunday,March 09, 2025, 03:33:17 PM »
  2.7 miles to first breakdown.
 Gathered up some courage and went for a test ride. After circling my neiborhood for a test I decided to go to a site of current car shows. Only 2.7 miles away and I overheated, blowing the hose off just before the swirl pot. Fords garage in background.
  Waiting for a tow !  Home is due north small dot in map pic.
I believe the brakes started dragging for some reason.
« Reply #98 on: Sunday,March 09, 2025, 04:25:59 PM »
Bummer, D’man! Have you figured out what caused you to overheat?
« Reply #99 on: Sunday,March 09, 2025, 04:46:40 PM »
  BDA, Just got it tucked in at home.  No previous leaks and I could run it at idle all day long, garage floor had only the gearbox leak.
  I just heard a loud pop and alot of white smoke, coolant line blew off swirl chamber. I attached the hose and added fluid but engine sounded like it was running on 2 cylinders.  tomorrow I'll have more data. A few threads above I mentioned a feeling of brake drag.
 Good thing it was Sunday and Chickfil la was closed.
« Last Edit: Sunday,March 09, 2025, 04:52:39 PM by dakazman »
« Reply #100 on: Sunday,March 09, 2025, 06:27:22 PM »
Well that is a bummer! Hope an easy fix ahead!
« Reply #101 on: Sunday,March 09, 2025, 08:40:44 PM »
Dakazman, I did Andy Hines’ gas strut approach many years ago. It worked out quite well. I did relocate the mid-engine-lid bar so the lid would be more vertical when open, to ease engine access. In general, I like the mod.
« Reply #102 on: Monday,March 10, 2025, 06:08:52 AM »
  Kendo,
 I returned the gas struts which I thought were to short the total length were about 8 inches extended. The attendant did the conversion of the strut to his vendor so he may have been wrong.
 Turbo, hopefully.
I thought it was a nightmare but my wife sent me this picture this morning. :headbanger:
Then still getting use to this time shift.
« Reply #103 on: Monday,March 10, 2025, 08:11:28 AM »
  Found this before I went out today, how these belts got loose all of a sudden. :blowup:
 More later,
Offline kram350kram
« Reply #104 on: Wednesday,March 12, 2025, 07:08:20 AM »
Not questioning your belt size selection but they seem not to fit the pulleys well? If the belt taper was incorrect might have worn in and slacken up?.
