Author Topic: Excellent '73 Europa Special restoration project. SOLD  (Read 6881 times)
Offline Wolfgang
« on: Wednesday,July 03, 2024, 12:11:29 PM »
1973 Europa Special 5 speed, excellent restoration project. SOLD.
⦁   Approx. 77,000 original miles
⦁   2 owner (I purchased it in '76.)  Have original receipts/complete history.
⦁   Engine was overhauled in '79 @68k miles.  Not run  since '84 (engine is out and on stand)
⦁   Body off and sanded down to primer.  Minimal stress cracks.
⦁   Chassis blasted and fully welded as per the competition manual.  Sprayed with 2 part epoxy.
⦁   Entire suspension rebuilt.  All bushings, rod ends and brake lines as new.  Spax shocks are older but have approx. 1500 miles.  Plumbing to a Nissan F-10 master cylinder.  New ball joints, u-joints and hub carrier bearings.  New front bearings, trunnions and a-arm bushings
⦁   5 speed inspected with new seals and transmission mounts.
⦁   Clear title, owners manual, shop manual and original factory warranty certificate.
⦁   Original mirrors, bumpers, fuel caps in excellent condition.
⦁   1 Willwood aluminum brake caliper (used for fitment purposes) and custom fabricated mounts for front brake conversion.  Miata rear disc kit (from Lotus group buy). Have original calipers and rear drums.
⦁   Cibie headlights.
⦁   New aluminum "Mac's" radiator kit (also from a group buy) which includes a Spal fan with relay and wiring harness.
⦁   Aluminum transfer pipes and stainless stone guard (group buy).  Have the original radiator and transfer pipes.
⦁   No windshield (cracked after removal).
⦁   Original black seats in good shape (small seam separation on drivers seat).
⦁   All original instruments in excellent condition.
⦁   Original carpeting to be used as a pattern.
⦁   Many original and partial restoration photos showing disassembly ect.......also notebook regarding same.
⦁   Original wiring harness completely labeled.
⦁   Custom aluminum alternator pulley.
⦁   Panasport wheels and 2 original apare tires on Lotus steel wheels.
⦁   Crossover pipes and large charcoal cannister are missing. Still have the secondary charcoal cannister.
⦁   All original receipts.
⦁   Dave Bean headers and parts catalog.
⦁   Stainless door hinges and Racemark steering wheel.
⦁   Original starter, alternator, brake boosters, carbs ect.
⦁   All original keys and even the elusive ash tray!
⦁   There's probably more stuff but these are the main points.
This is basically a complete original example that needs to be finished up.  The car is located in Northeast Missouri on the Mississippi river.....about 90 miles north of St. Louis in Hannibal Missouri.  I'm going to ask $6,700 for the lot and it's reasonable to assume there's significantly more in it than that.  I would love to see the car finished to a very high standard and put back on the road or show circuit but I seem to be running out of time......
Thanks for your interest and kind regards,
BW
« Last Edit: Monday,August 12, 2024, 08:13:06 AM by Wolfgang »
Re: Excellent '73 Europa Special restoration project.
« Reply #1 on: Wednesday,July 03, 2024, 12:25:56 PM »
You may be a short-timer here but  :Welcome: Wolfgang!!!! You're certainly welcome to hang around after you sell your project!
You appear to have a lot of good parts and a good start on a full restoration. I hope it finds a good home!
Offline Wolfgang
« Reply #2 on: Wednesday,July 03, 2024, 02:21:33 PM »
Actually I'm a long time member and came here directly from the europa on line knowledge base (after it's demise).  I haven't been active on the site for quite some time and couldn't log in for some reason.....so I had to re-register.  Thanks for the kindly welcome never-the-less! I have an '06 Exige as well (been a hard core Lotus fan since Jim Clark embarrassed everyone at the Indy 500 with the huge win....I believe he was on the cover of "Boy's Life" after that.
Offline s2europa
« Reply #3 on: Wednesday,July 03, 2024, 02:35:58 PM »
Would be helpful to post pictures in its current condition. Thanks.
Offline Wolfgang
« Reply #4 on: Friday,July 05, 2024, 07:17:21 AM »
Can someone kindly explain to me how to post photos?????
Offline Dreamer
« Reply #5 on: Friday,July 05, 2024, 07:19:09 AM »
When you post look at the bottom of the page and you'll see where it says; Attachments and other options. Click on that and then click on Browse to find the image you want to post. NOTE: there is a size limit. To post more photos hit More Attachments below the file you just loaded and a new Browse window will open.
« Last Edit: Friday,July 05, 2024, 07:29:24 AM by Dreamer »
Living life on the edge. Less crowded, better view!
Offline Dreamer
« Reply #6 on: Friday,July 05, 2024, 07:30:24 AM »
And of course I forget to post the screen shots to go with that last post.
« Reply #7 on: Friday,July 05, 2024, 07:38:39 AM »
I get the photo which is too large a file and use Microsoft Snipping Tool which seems to change it to a much smaller file instantly, plus you can use it to reduce the area of the photo cutting out any irrelevant stuff.
« Reply #8 on: Friday,July 05, 2024, 08:13:32 AM »
I used 4129R's method too. Apple has a similar utility that youtube will be glad to show you how to use.
Here's a video to show you how to use the snipping tool. The reason it works is it converts your high resolution picture to a picture with the resolution of your screen which is much lower.
https://www.youtube.com/watch?v=O_55eg00H-w
The "official" method of resizing your pictures is here: https://www.lotuseuropa.org/LotusForum/index.php?topic=1379.msg12166#msg12166
« Last Edit: Friday,July 05, 2024, 08:42:26 AM by BDA »
Offline Wolfgang
« Reply #9 on: Friday,July 05, 2024, 11:47:16 AM »
Here are a few pics:
« Reply #10 on: Friday,July 05, 2024, 11:53:48 AM »
Nice frame!
How much for the rug?  :FUNNY:
Offline Dreamer
« Reply #11 on: Friday,July 05, 2024, 01:31:56 PM »
Nice frame!
Why? You trying to pull the rug out from under him?? Asking for a friend.  ;)
Offline cec9797
« Reply #12 on: Tuesday,July 23, 2024, 03:36:04 PM »
PM sent
« Reply #13 on: Tuesday,July 23, 2024, 07:20:28 PM »
I don't mean to horn in on this thread but I wanted to say
 :Welcome: cec9797!!
