Author Topic: Getting derailed  (Read 25081 times)
Getting derailed
« on: Thursday,March 21, 2024, 05:44:03 PM »
   I admit I’ve been slacking on getting a few dozen honey-do’s done.🥱 however then the proverbial s*** hit the fan .
  Spring came and opening the pool is a must along with pressure washing everything. Then just when finished with that, my pool pump died. Replaced it and on to the next job of expanding the dog run with fencing all around. Then a driveway gate to keep people out. Then a brake job on my van and while that was ongoing, my tiberon wipers died, motor good but the entire gearing and rod’s needed replacing. Luckily Dorman had the assembly.👍👍.
Then back to the van with a few problems that had no codes, speedometer at 100 and only moving about 40. Then engine dies and trans not shifting. After a tuneup same problems , a vss on the trans no help . Then I got a code nbr 3 cyl. Replaced plug which looked Fouled did not fix it so I checked the distributor cap only to find nbr 3 open from contact to plug . It was brand new . No running good but still doing 100 . Back in I went cleaning grounds and checking for more chewed up wires.
   Since I was in the car I decided to fix a few other things that they don’t sell parts for . NLA is the theme on my cars. Funny thing was since I spend time looking for parts I found a deal on rear shocks that I needed for my EL Camino 😂👍 that job only took two hours to install a new set of air shocks in the rear .
  Then rebuilding an Pella awning window the rotted out 2k to replace but with 150$ of wood all better now.
  I hope this is it but I’m old enough to realize it’s probably not.
Re: Getting derailed
« Reply #1 on: Thursday,March 21, 2024, 11:14:00 PM »
At least you have good weather !  Can you send some of those blue skies over here please ?
« Reply #2 on: Friday,March 22, 2024, 05:04:55 AM »
 I’ll try,
 It wasn’t all that bad , I got to go to a car show but sadly without my car.
 Here are some pics of some beautiful cars.
« Reply #3 on: Sunday,March 24, 2024, 03:22:39 PM »
  Another minor job turned into a all day affair.
   a simple ground cleaning with a power antenna module swap-out turned into a nightmare.
Sorry, I have maybe some pics of the area that I can post, but I just wanted to complete this job. To get the antenna out the battery needed to come out, no problem until the hold-down bolt snaps off. then I remove the tray that holds it down and find everything rotted out.  No problem ,I remove the tray... :FUNNY: then I have to make up a plate to hold the battery in place. Two hours later everything going back together , Maybe. The universal fit antennas mask is to short and its wiring is not anything like OEM. anyway its back together except for the connections to the radio. tomorrow is another day.
« Reply #4 on: Friday,April 05, 2024, 03:00:48 PM »
  Who would have thunk it.
  The cause of my 1998 GMC van stalling maybe even shutting down at 40 MPH was the instrument cluster .
 The airmotor provides a signal to the ecm provided by the VSS . my speedometer would bounce around and peg out at 100 mph when only doing 40.
 after talking to a GMC parts person they said they had tons of problems with this. I ordered a complete cluster from a salvage yard and was skeptical it would fix the problem. the individual 'Stepper motors '( now called airmotors)were more expensive.
  Even my 2012 sonata wanted some maintenance. I brought her to the dealer. @ repairs done for free. I even get to park it back in the garage...But dont tell my wife.
 Well now I have all my cars running again, now to put them on the road.
« Reply #5 on: Friday,April 05, 2024, 03:03:10 PM »
 :beerchug:
Now that you got those other cars out of the way, it's time to get the Lotus on the road!!  :)
« Reply #6 on: Friday,April 05, 2024, 06:54:41 PM »
 Absolutely BDA , besides I needed the van to pull a trailer and to store the lotus . 😁👍👍
« Reply #7 on: Wednesday,May 01, 2024, 12:47:04 PM »
  I just about finished building and awning for a window. Piecing it together with aluminum screen enclosure material and a metal roof. Topped off with my wife color of choosing.
  Then I’ll need to hang it on its hinged top rail which will be supported by two steel rods.
  Then back to the Europa.
Dman
« Reply #8 on: Thursday,May 16, 2024, 07:03:55 PM »
  I think I’m done with the honey-do’s.😂🙏🙏🙏
  But then there are my daughters list.
   While waiting for some new instrument light socket bases and some bulbs I knocked out o few jobs. The canopy to block the morning sun.. done then making something to hold thes antique mirrors to the wall. I cut some plywood and will glue the mirrors to but first attaching a wire hanger wire.  Then is another project, she acquired an all electric Vespa that has a battery problem, so her,” Dad can fix it ,” idea came out .🥱 So I need to go pick it up and fix.
 Then I got to be a grandfather and read stories to my granddaughter. Fun time.
« Reply #9 on: Friday,May 17, 2024, 05:44:29 PM »
  Got to clean up the lines in the graphics. I did it freehand and will nib sand till I get it perfect, then reclear the entire panel. I love making people bring out the magnifying glasses 😂
  I doubt this will be attached to my car but I’ll try my best to keep the JPS theme alive.
« Last Edit: Saturday,May 18, 2024, 07:31:57 AM by dakazman »
« Reply #10 on: Friday,May 17, 2024, 06:05:13 PM »
Looks really nice, D’man!
« Reply #11 on: Sunday,May 19, 2024, 02:58:36 PM »
  I also finished my daughter’s beveled mirror backing, and a new handle for my favorite knife.
  Oops I didn’t take o pic of the backing. Used all the windscreen adhesive to hold those mirrors on a piece of 1/4 plywood. It's still a work in progress.
« Last Edit: Sunday,May 19, 2024, 03:00:56 PM by dakazman »
« Reply #12 on: Thursday,May 23, 2024, 07:00:47 PM »
  Just when I thought I was getting back to the Europa, my daughter picked up a stray.
  Needs a complete set of 12v 20 ah 6 each batteries. All the ones in there were swollen so bad It took forever to get them out.
  Then she wants a full paint job.
« Reply #13 on: Friday,May 24, 2024, 11:34:56 AM »
Nah, convert it to run on GAS!
« Reply #14 on: Friday,May 24, 2024, 03:45:04 PM »
  That’s what I said but … that would take longer.  Got it de cowled, needs brakes shoes and some fluid . I found the batteries on eBay for about 250$ for all six 12v 20ah lead acid .  I’m still hunting around for something that will fit using the charger limits suits for 72v20ah.  The batteries that were in there were 6-DZF-20 Lead acid. \
  Then my other daughter is looking at a sailboat :huh: :help:
« Last Edit: Friday,May 24, 2024, 03:50:48 PM by dakazman »
