Author Topic: Giday From Aus - and is there a Dash auto cad file in existance  (Read 2895 times)
Re: Giday From Aus - and is there a Dash auto cad file in existance
« Reply #15 on: Monday,April 14, 2025, 08:13:30 PM »
Well  RATS, I went to the trouble of joining the Groups IO and still cannot find/access the S2 Dash file.
It "Should" be possible to make new ones using my CNC mill.
I cannot do them in one pass as they are too long for that.
But if I run the mill dry and remove the end panels I think it very possible.
Quotes I got are silly, $1,200+ silly!
I have the tools to do veneering.
I must find products for the CNC machines ASAP.
« Reply #16 on: Monday,April 14, 2025, 09:19:43 PM »
Looking at an old dash it is apparent that they were routered from the back side.
My CNC mill only has 20" of X travel.
So to do them means re-positioning twice for the 48" piece.
Inconvenient, but not impossible.
Update: I am now on the hunt for an inverted pin router.
I've sort of wanted one for a while now.
They are not expensive but the good units are Heavy so not easy to get home.
« Last Edit: Tuesday,April 15, 2025, 09:33:52 AM by Richard48Y »
« Reply #17 on: Tuesday,April 15, 2025, 10:07:32 AM »
I found this dash pattern on the groups.io group: https://groups.io/g/LotusEuropa/photo/157183/1844248?p=Name%2C%2Cdash%2C20%2C1%2C60%2C0 Is this what you were looking for?
« Reply #18 on: Tuesday,April 15, 2025, 11:37:54 AM »
It might be, if I could complete a log-in.
« Reply #19 on: Tuesday,April 15, 2025, 11:45:22 AM »
Take a look.
« Reply #20 on: Tuesday,April 15, 2025, 03:12:04 PM »
A very good start but I do not see some of the dimensions.
I can measure and add from mine.
Not sure why the delay at Group IO.
« Reply #21 on: Tuesday,April 15, 2025, 04:21:04 PM »
  I have the original s2 dash template, I'll add the missing dimensions for you.
   Mine had a secondary fan switch, not original.
  I'll post the missing dimensions ASAP depending if the photo BDA supplied can print.
« Reply #22 on: Tuesday,April 15, 2025, 08:45:23 PM »
If I can find a suitable piece of aluminum I hope to make a hand-router pattern until a better answer comes along.
« Reply #23 on: Thursday,April 17, 2025, 09:34:58 PM »
A good start but curvatures and distances from center lines not given.
I think I will try to see how far I can get with this as a starting point and my old dash to try to get more from.
Any additional info will help.
