Author Topic: alt pulley modification for TOYOTA 4AGE  (Read 1409 times)
Offline ralf
« on: Wednesday,September 21, 2022, 09:10:07 AM »
Hello,
I swap the engine od my Europa to the TOYOTA 4AGE engine.
The 4AGE has its pulley for the alternator at the front of the engine which I don't like.
So I convert the 4AGE engine to a camshaft driven alternator pulley.
Therefor I let cast a aluminium bracket to hold an additional rollerbearing in the center if the pulley.
If you have a bearing in the center of the pulley you will not have a radial force by the V-belt to the extension of pulleyshaft.
Re: alt pulley modification for TOYOTA 4AGE
« Reply #1 on: Wednesday,September 21, 2022, 09:12:45 AM »
Very interesting! There aren't many (any?) of us who cast our own parts!  :welder:
Offline ralf
« Reply #2 on: Wednesday,September 21, 2022, 09:18:06 AM »
The cylinderhead and valvecover need an opening for the O-ring area of this bracket. because I dont have a big milling mashine I used a manual Hunger valveseatcutter. A guide was made to position the cutter in the center of the camshaft.
Offline ralf
« Reply #3 on: Wednesday,September 21, 2022, 09:25:27 AM »
On my 4AGE I use a non original valve cover. With he Hunger I cut the bore in the head and the cover fixed together.
Offline ralf
« Reply #4 on: Wednesday,September 21, 2022, 09:26:38 AM »
The finished bore looks like this.
Offline ralf
« Reply #5 on: Wednesday,September 21, 2022, 09:28:06 AM »
At the cylinderheadside of the bracket there is diameter with an O-ring.
Offline ralf
« Reply #6 on: Wednesday,September 21, 2022, 09:30:31 AM »
At the inner of the other side of the bracket there is a bearing hold in axial position by a ring and a seal (not at the picture)
Offline ralf
« Reply #7 on: Wednesday,September 21, 2022, 11:08:00 AM »
The bracket is fixed at three points to the rear of the cylinderhead
Offline ralf
« Reply #8 on: Wednesday,September 21, 2022, 11:10:28 AM »
The pulley is from a frensh 50ccm motorbike. To position the V-Belt at a level with the bearing a adaptor was made snd screwed to the pulley.
Offline ralf
« Reply #9 on: Wednesday,September 21, 2022, 11:16:54 AM »
The conection of the pulley should be flexible. So I made a adapter which could at the one side pressed to the camshaft. At the other side a cut sproket of a Honda CB50 was fitted.
Online TurboFource
« Reply #10 on: Wednesday,September 21, 2022, 12:07:46 PM »
Nice work Ralf!
« Reply #11 on: Wednesday,September 21, 2022, 02:01:45 PM »
Very nice indeed!
Offline ralf
« Reply #12 on: Wednesday,September 21, 2022, 08:55:16 PM »
Thanks,
the adapter is pressed to the camshaft and additionaly fixt with a 4mm pin which was fixed by a laser weld.
Offline ralf
« Reply #13 on: Wednesday,September 21, 2022, 08:56:21 PM »
The pressed in sprocket was also fixed with three laser spots.
Offline ralf
« Reply #14 on: Wednesday,September 21, 2022, 09:02:12 PM »
The outside of the camshaft extension is made by the shortened transmission shaft of a 1978 Honda CB50 (same shaft like the XL75/80 XR80.. which was sold in the US) and a adapter.
