Author Topic: I auto crossed my Europa again  (Read 4934 times)
Offline rjbaren
« on: Thursday,August 18, 2022, 04:27:11 AM »
This year I auto crossed my Europa again with the BMW club.  The car performed as it should with no problems at all.  I also put some Toyo tires on a set of Cosmic wheels.  I ran with 205 60 13s rear and 185 60 13s front.  Wheel wise, the rears are 6" wide, and the fronts are 5.5 inches wide.
In September of last year, I auto crossed with Barum street tires in the stock sizes and the car did OK but slid more than I wanted.   This time the grip was much better.  Last year I was 2nd to last of all cars and this year I was 2nd to last in my class but faster than a number of cars in other classes.  Unfortunately, out of 8 runs I DNFed once, and hit a cone on all but 2 runs.  So, I believe the car is up to snuff, but my driving ability needs work.   Then again, I was running against injected cars with ABS, and traction control.  A lot of M2, M3s and M4s, two Mustang GTs and 4 Corvettes including a Z06 that I almost beat, a few Porches and of course some Miatas.  All in all, it was a lot of fun.
Re: I auto crossed my Europa again
« Reply #1 on: Thursday,August 18, 2022, 07:24:10 AM »
Great progress and great fun!  :trophy:
Offline Polopharm
« Reply #2 on: Thursday,August 18, 2022, 09:02:56 AM »
Hi. Good work just getting out and doing it!
My limited experience with autocross( i have a lot of road course miles) is your 1st and 2nd gear ratios are very important to quick times. Also in a relatively low power car its even more important. You need the grunt to accelerate from a near standstill but also the ability to wind it out as the least shifting you do the better.
« Reply #3 on: Thursday,August 18, 2022, 09:07:18 AM »
Wow, that sounds great. Keep at it, until you can spank those Vettes.
« Reply #4 on: Friday,August 19, 2022, 12:46:33 PM »
Awesome. I assume R888R's. If so it sounds like you are hooked. As with anything, you get better/faster the more you do it and find the limit. Any pics?
Offline rjbaren
« Reply #5 on: Friday,August 19, 2022, 02:18:06 PM »
Here is a picture taken during a run.  I can't believe I got it to load.
« Reply #6 on: Friday,August 19, 2022, 02:51:46 PM »
Looking good on three wheels!!  :pirate:
« Reply #7 on: Saturday,August 20, 2022, 02:46:52 AM »
That's a frame worthy pic.
« Reply #8 on: Saturday,August 20, 2022, 04:28:54 AM »
 8)
« Reply #9 on: Monday,August 22, 2022, 08:50:18 AM »
Woohoo! Pulling a wheel. Cool photo.
Offline Polopharm
« Reply #10 on: Monday,August 22, 2022, 10:23:07 AM »
Would tightening up the front end, getting less roll help? Assuming its not a high speed turn, i would think it would help. Not sure if these cars are that much different for set up.
« Reply #11 on: Monday,August 22, 2022, 02:01:42 PM »
A lot of cars lift a wheel with sticky rubber and especially with heavier bars. Mine does.  Most front wheel drive cars lift a rear. You just don't want a rear drive car lifting a rear tire. If you look at a lot of autocross pics, you will see it often.
Offline rjbaren
« Reply #12 on: Friday,August 26, 2022, 12:47:14 PM »
You make a good point, so I printed and framed it.
« Reply #13 on: Saturday,August 27, 2022, 08:38:22 AM »
Cool. I did one of mine and hung it  the garage with some other past rides in action. These kind of pics are much more harder to come by than just a parked one.
Offline Polopharm
« Reply #14 on: Saturday,August 27, 2022, 10:47:20 AM »
It is  a great picture and I understand about lifting a wheel.
In the picture it looks like the rear is squating down likely under acceleration and the front is lifting and rolling, which would add more understeer.
That was my point.
