Thank you JB. I am continually out of my depth so I have a question for you. With an engine that was fully rebuilt under a year and a half ago it shouldn't be experiencing excessive blow by right? I have put less than a 1000 miles on it. New pistons, cams, porting, etc (fuel pump rebuilt) really the works. The engine was up rated to 150 hp at the crank so is there a chance the original glass bowl fuel pump is not up to the task?
I think my first step will be to rebuild the fuel pump and see what the results are. If results are no better then It may lead to me replacing the pump altogether with a different one and going from there.
