Author Topic: The revival of 650143R, 1970 with TS.  (Read 87965 times)
« Reply #765 on: Friday,April 04, 2025, 11:09:41 PM »
Third time the charm?
I have ordered another adjustable cam gear and hub.
All I really needed was the hub.
At $200 each I HAVE to stop ruining these.
I cannot get dry ice locally so may give in and have a machind shop do it for me.
A "Galling" situation.
« Reply #766 on: Saturday,April 05, 2025, 07:46:12 AM »
Good luck! That sounds really frustrating and expensive!
« Reply #767 on: Saturday,April 05, 2025, 08:22:41 AM »
At least my front bumper only had to be chromed once, $700.00.  :huh:
« Last Edit: Monday,April 07, 2025, 08:38:19 PM by Richard48Y »
« Reply #768 on: Tuesday,April 29, 2025, 09:35:49 PM »
I am about sick.
I gave in and had a local machine shop make the third try on my cam gear.
Cost me $100 and is ruined again.
So I will have to get yet another.
Something must be out of spec here.
I am beggining to think the cam nose is an RCH too large?
« Reply #769 on: Saturday,May 03, 2025, 07:42:59 AM »
The interference fit must be too tight.  You could also heat the hub prior to fitting, just like you do with an axle bearing retainer.
« Reply #770 on: Sunday,May 04, 2025, 08:54:52 PM »
Machine shop heated the hub and chilled the cam nose in dry ice, still no good.
They are saying .004" fit.
I am going to contact CAT Cams to ask for the correct cam nose specification.
Not sure where I could get this one reduced, needs to be ground not just turned.  :headbanger:
« Reply #771 on: Monday,May 05, 2025, 12:39:43 AM »
I'm no engineer, but...    (don't ya love it when people start out like that)
Anecdotally, - 0.004" seems like an extremely tight fit given the shaft diameter.
There's a wealth of tolerance charts, materials ect. out there, but I found this site:
https://www.engineersedge.com/calculators/mechanical-tolerances/force-fit-tolerances.htm
In the calculator, I selected "FN2" as the fit type - the suggested maximum for high grade cast iron.
I entered 1.00 inch as the shaft diameter.
The calculator output for interference fit suggested:
Max = 0.00190 inch
Min = 0.00060 inch
Any thoughts from our resident engineers?
« Reply #772 on: Monday,May 05, 2025, 03:49:40 AM »
Richard couldn’t it be honed to size on something like a Sunnen?
« Reply #773 on: Monday,May 05, 2025, 12:24:24 PM »
I have to get an exact measurement of the camshaft nose.
Then I will do the same for the new hub.
With that I think honing out the hub will be safer than trying to reduce the camshaft nose diameter.
It is unfortunate that with all the tools I have I still don't have what I would need to do this myself.
I can't really justify it for one time use.
« Reply #774 on: Monday,May 05, 2025, 07:27:55 PM »
Hey Rich, I believe I still have a cat cam sitting in my shelf I can measure it tomorrow.
Sorry to hear about your troubles.
« Reply #775 on: Monday,May 05, 2025, 09:21:42 PM »
I am strongly suspecting mine may be just a literal fraction oversize.
I do not have an original cam to measure for comparison.
I have sent an email to Cat cams, I hope they answer quickly.
« Reply #776 on: Thursday,May 08, 2025, 06:03:38 AM »
4 thou press fit on that size of shaft?  Way too tight as you already know all too well.
« Reply #777 on: Thursday,May 08, 2025, 07:56:08 PM »
Measured my cam nose, it is .0003" over maximum.
That really should not be enought to be such an issue.
On the next try I will have help from a guy who can measure with pin gauges before and after heating.
He has the proper oven and infrared temp gun.
We will exactly know much it will grow at 700º - 800º.
Goal is that it DROPS on this time.
If it does have to be honed I will get that done.
