Author Topic: Europa TCST  (Read 158966 times)
« Reply #345 on: Monday,August 30, 2021, 06:50:20 PM »
Just add a washer.
Offline Gary t
« Reply #346 on: Tuesday,August 31, 2021, 07:53:48 AM »
Not trying to start anything but a bushing is unlikely to be much easier than a custom bolt, you will need a lathe for either option.
Gary Toffelmire
54/1173
« Reply #347 on: Tuesday,August 31, 2021, 08:43:20 AM »
If I were going to make one, I would get a 1/2" bolt, 2" long, turn down the end to 3/8" for 1/2" long at the end, cut a 3/8" UNF thread on the 1/2" end, and use a penny washer to make it wider at the top.
I would also smear the thread with copper-ease to stop it rusting in the chassis again. But the reaction lever is seldom removed, normally only the take the body off the chassis, or to change from LHD to RHD or vice-versa.
Offline Gary t
« Reply #348 on: Tuesday,August 31, 2021, 09:14:36 AM »
That is (except for sizes) exactly what I did for the bolt at the bottom of the shifter. On that bolt it is important that the head is the correct size so the welded on anti rotation thing works.
Gary Toffelmire
54/1173
« Reply #349 on: Tuesday,August 31, 2021, 02:14:07 PM »
Bought 2,flange bushings, washers and a grade 8 bolt (will shorten bushings and bolt so arm pivots on bushings.) Greased on assembly it will last quite awhile!
Offline Gary t
« Reply #350 on: Tuesday,August 31, 2021, 03:11:45 PM »
Should work a treat. But some of us are always searching for an excuse to uncover the lathe.
Gary Toffelmire
54/1173
« Reply #351 on: Tuesday,August 31, 2021, 05:45:18 PM »
Gary,
If I had a lathe I would do so!
« Reply #352 on: Monday,September 06, 2021, 12:26:07 PM »
Shortened bushings and bolts for emergency brake arm.
Disassembling front hub etc....
Cleaning more pieces...
« Reply #353 on: Sunday,September 12, 2021, 11:56:55 AM »
Coolant lines cut and ready for welding.....: :welder:
« Reply #354 on: Sunday,September 12, 2021, 04:17:17 PM »
  Nice work turbo.
I may have said this before but remember to put new seals in the frame before installing the tubes.
« Reply #355 on: Sunday,September 12, 2021, 06:35:51 PM »
Already done Dman!
« Reply #356 on: Monday,September 20, 2021, 02:09:34 PM »
Today's progress.....
Turned chassis into temporary work table.....
Then  :welder:
Going to weld tabs on heater tubes and then pop rivet them in place, also need to weld NPT weld bungs in place for heater hoses etc. on coolant tubes.
« Last Edit: Monday,September 20, 2021, 02:14:14 PM by TurboFource »
« Reply #357 on: Monday,September 20, 2021, 02:24:29 PM »
Excellent!!! Another step in your journey!  :beerchug:
« Reply #358 on: Monday,September 20, 2021, 02:39:34 PM »
  Again nice work Turbo .   I hope this next step goes smoothly for you ,   Now for the fun part, getting them in.
   dakazman
« Reply #359 on: Wednesday,September 22, 2021, 08:08:16 PM »
Very pretty welds there, Turbo.  8)
