Author Topic: Plumbing: looking for inspiration  (Read 1105 times)
Offline elcaminokid
« on: Tuesday,September 17, 2019, 03:13:18 AM »
Hi all,
The time has come to replace my water pump (luckily on an S2 Renault engine).
I think this is the right time to review the plumbing on the engine, as right now it's a cobbled together mess of hoses, hose joints and jubilee clamps.
Does anyone care to share some pictures of their plumbing?
Offline 1970EuropaGuy
    • Lotus Europa Restoration
Re: Plumbing: looking for inspiration
« Reply #2 on: Tuesday,September 17, 2019, 07:42:59 AM »
This is what my S2 looks like. Whether it's 100% original I don't know but at least the plumbing is cleanly done.
« Reply #3 on: Tuesday,September 17, 2019, 09:22:14 AM »
Not stock.  Missing heater valve, heater hoses are cobbled together with pipe bends and clamps, right side main pipe is cobbled as well.
Offline elcaminokid
« Reply #4 on: Tuesday,September 17, 2019, 11:54:30 AM »
I don't mind if it's not stock. There's not a lot 'stock' left on my car  :pirate:
Offline Nero
« Reply #5 on: Tuesday,September 17, 2019, 01:02:43 PM »
A lot different then stock but also a lot cleaner
« Reply #6 on: Tuesday,September 17, 2019, 01:51:37 PM »
The hose from the water pump bleed to swirl pot is bypassing hot coolant from going through the radiator.
Offline Nero
« Reply #7 on: Wednesday,September 18, 2019, 06:39:26 AM »
Yes it does. We only made a very small hole, a lot smaller than the hose for bleeding. This helped a lot and the car doesn’t overheat even in last years summer with nearly 40°c(very hot for Germany). The car actually runs a bit on the cold side when it’s just 20°c.
« Reply #8 on: Wednesday,September 18, 2019, 10:41:33 AM »
Good, I was going to suggest a metered orifice.
Offline Gmg31
« Reply #9 on: Thursday,September 19, 2019, 01:58:54 AM »
I replaced some of my rubber pipes with silver copper pipes.
Offline elcaminokid
« Reply #10 on: Friday,September 20, 2019, 09:50:22 AM »
That's very neat! Are those pipes of something else, or you bent them yourself, using straight stock? Do they have a bead at the end to keep the hose in place?
« Reply #11 on: Friday,September 20, 2019, 12:18:02 PM »
You should put a bead.  Sometimes you can’t and a few pop-rivets do the trick just as well.
