Author Topic: Need Left & Right Engine bay “Tie Mounting Brackets”  (Read 716 times)
« on: Saturday,May 18, 2019, 09:39:50 PM »
yes, that is what they are called in the parts manual “Tie. Mounting”.  The metal rods that bolt to the body in the engine bay.  I need both left and right side.  The bolts on mine snapped off (all 4 on each plate) and I thought I could just grind off the bolts (they are welded in) and install new ones. More difficult than I need it to be.
Anyone have a pair for sale that the bolts are intact or have the bolts removed?
« Last Edit: Monday,May 20, 2019, 04:16:11 AM by Certified Lotus »
Re: Need Left & Right Engine bay “Tie Mounting Brackets”
« Reply #1 on: Monday,May 20, 2019, 11:35:58 AM »
Located a pair. All good.
« Reply #2 on: Monday,May 20, 2019, 01:12:37 PM »
It is very easy to drill through from the bolt side, and just replace the broken stud with a 1/4" UNF bolt.
Been there, done that.
« Reply #3 on: Monday,May 20, 2019, 01:42:09 PM »
I had thought of that but after drilling, grinding and rewelding new bolts it is cheaper to acquire a used pair in good condition. Was only going to go that route if I couldn’t find a pair. I lucked out.
