Author Topic: Refitting Body .. Problem  (Read 1636 times)
Offline nigelc
  • S2 54 under restoration and S2 47 style
« on: Wednesday,December 12, 2018, 08:27:11 AM »
Hi All .. finally putting the body back on the chassis but have hit a problem. the shell no longer wants to sit down over the backbone of the chassis . I have used closed cell foam soundproofing that is 10mm thick , that seemed to be reasonable based on thickness of original material ?. Anyone else had problems , are they all a really snug fit , any suggestions before i take it off and use a thinner gauge of foam   Thanks guys
Re: Refitting Body .. Problem
« Reply #1 on: Wednesday,December 12, 2018, 09:23:24 AM »
10mm sounds too thick to me.
Offline RoddyMac
« Reply #2 on: Wednesday,December 12, 2018, 09:24:04 AM »
I think 10mm is a bit thick.  I used 1/4" (6 mm) closed cell and it was a tight squeeze.  I glued mine in sections, top, sides etc, and had the side pieces start to peel back at the top which added to the difficulty in lowering the body.  I don't think closed cell compresses as thin as the jute/horsehair pads that the car originally had.
Offline nigelc
« Reply #3 on: Wednesday,December 12, 2018, 10:22:00 AM »
Thanks .. i feared that may be the case .. right off it comes again then .
« Reply #4 on: Wednesday,December 12, 2018, 11:01:54 AM »
I had the same problem on 4688R.
The seat belt bolts would not fit in the centre of the chassis.
Use 6mm.
Thanks for reminding me. I have at least 3 more to fit.
Offline nigelc
« Reply #5 on: Saturday,December 15, 2018, 01:04:54 PM »
Success .. lifted the body back up, old foam off , new 5mm foam on .. fits like a glove . Body finaly back on a chassis for the first time in 20 years .
« Reply #6 on: Saturday,December 15, 2018, 02:48:06 PM »
Excellent!!!! That's a good feeling, isn't it?  :beerchug:
« Reply #7 on: Saturday,December 15, 2018, 05:10:34 PM »
 :ttiwwp:
« Reply #8 on: Sunday,December 16, 2018, 02:56:16 AM »
Where did you get the 5mm foam?
I will be needing lots soon.
Offline nigelc
« Reply #9 on: Monday,December 17, 2018, 04:06:32 PM »
BDA .. yes , brilliant feeling
Certified .. i agree, will do pics when next at the workshop .. phone batt died when i was fitting body so sadly couldn't capture the success at the time
4129r - foam came from ebay , £25 for a 2m x 1m sheet of 5mm closed cell adhesive backed . i you want i can see if there were any direct contact details on the invoice as it may be a bit cheaper going direct rather than through ebay ?
