Author Topic: Lotus news 1987 sage advice  (Read 1290 times)
« on: Saturday,September 29, 2018, 09:01:35 AM »
When was the last time you changed your fuel lines?
https://jbcollier.smugmug.com/Lotus-Europa/i-9C2rmJ8/A
Re: Lotus news 1987 sage advice
« Reply #1 on: Saturday,September 29, 2018, 09:20:59 AM »
I find all sorts of crap in the bottom of the tanks too.
I am changing to 6mm copper fuel lines, using compression gas fittings.
« Reply #2 on: Saturday,September 29, 2018, 10:51:10 AM »
I run 5/16”/8mm lines.  1/4”/6mm is a bit small.
« Reply #3 on: Saturday,September 29, 2018, 11:04:22 AM »
I thought the pipes coming out from the tanks were 6mm ID.
If so, anything bigger later in the line would be restricted by the diameter of the exit from the tanks.
« Reply #4 on: Saturday,September 29, 2018, 10:46:05 PM »
It is, or at least it was on my original tanks.  And if the 6mm restriction wasn't at the tank you'd hit the same thing at the pump inlet and then at the dellortos on the TCs.  But I missed a trick when I made my tanks because a larger outlet would have meant that the tanks balanced themselves quicker when filling up. With a 6mm balance you need to fill one tank and then move over to the other one if you want to get the most fuel in you can, I think a 10mm balance branching to a 6mm feed line would be much better.
