Author Topic: My last gas tank installation question  (Read 1316 times)
Offline Runningwild
« on: Monday,June 18, 2018, 11:54:21 AM »
In the pictures you can see a bump in the filler neck casting. I assume the filler hose goes over it and the clamp goes on the flat part of the neck. Not sure what that bump is for.
Re: My last gas tank installation question
« Reply #1 on: Monday,June 18, 2018, 07:19:56 PM »
By any chance is there a corresponding notch in the opening for the filler housing in the car body? Maybe to orient the filler cap hinge? Other than that, dunno.
« Reply #2 on: Monday,June 18, 2018, 09:46:51 PM »
This might sound odd, but my first impression was that it was a boss to be drilled/tapped for a breather tube to a filter.  Mine's just a straight tube but I couldn't say if it's OEM or later addition.
« Reply #3 on: Monday,June 18, 2018, 10:55:29 PM »
Yup, it’s an undrilled boss for a breather.  The hose does not go over it.
Offline Runningwild
« Reply #4 on: Tuesday,June 19, 2018, 04:24:49 AM »
Thanks John. Tank is mounted now just connecting the filler hose.
« Reply #5 on: Tuesday,June 19, 2018, 04:48:48 AM »
Cool. Learn something new all the time!  :beerchug:
« Reply #6 on: Tuesday,June 19, 2018, 05:55:21 AM »
Tom, that looks like a TC filler with a flip cap. I thought you were fitting a S2 tank.
Online 4129R
« Reply #7 on: Tuesday,June 19, 2018, 07:09:55 AM »
All 12 (6 pairs) that I have removed from TCS have a small vent tube there which corresponds to a small notch cut in the fibreglass.
I renew the 50mm (2") rubber tube, but retain the clips, as so far I have not seen a badly corroded clip.
The rusting on the tank tops is a different story. Some tanks have more hole than metal left.
Offline Runningwild
« Reply #8 on: Wednesday,June 20, 2018, 06:44:02 PM »
The flip up gas filler came with the car. Ordered a vented unit that will mount to the body as well as flexible 2” hose. Hopefully this will make it easier.
