Author Topic: Front Upper Wishbone Halves  (Read 505 times)
« on: Tuesday,March 21, 2017, 11:36:18 AM »
I'm not using the stock front upper A-arms but I have two that I want to sell and I assumed that there are only two different parts and the A-arms on one side are the same as the ones on the other side only upside down. Now I find that's not true. There are four different part numbers for them. How do you tell which is which?
Offline RoddyMac
Re: Front Upper Wishbone Halves
« Reply #1 on: Tuesday,March 21, 2017, 12:05:25 PM »
The mounting holes for the upper ball joint are at different angles.  If you look in the suspension portion of the workshop manual you should be able to see the angle at which the holes are drilled.
« Reply #2 on: Tuesday,March 21, 2017, 12:24:48 PM »
I see it! Thanks Roddy!
