Author Topic: Soundproofing Chassis  (Read 5519 times)
Offline Gmg31
« on: Friday,September 04, 2015, 12:37:25 PM »
stripped down the chassis today.  All the old sound proofing is very old and tatty so ripped  it all off and the chassis is In perfect condition underneath.  So having looked on eBay there are two good replacements.  Silver pads or black matting.  Anyone got any experience of these products.
Re: Soundproofing Chassis
« Reply #1 on: Friday,September 04, 2015, 01:28:32 PM »
Find some closed cell neoprene foam. r.d. enterprises on this side of the pond sells some. I found some locally by checking the phone book. I used a 3/8" thickness.
« Reply #2 on: Friday,September 04, 2015, 02:51:55 PM »
I used a silver backed closed foam.
« Reply #3 on: Friday,September 04, 2015, 04:50:46 PM »
B-Quiet:
http://www.b-quiet.com/products/b-quiet-ultimate-50sqft
And then put the rdent.com closed foam.
Offline Gmg31
« Reply #4 on: Saturday,September 05, 2015, 11:53:09 AM »
Some great ideas there thanks. I've ordered some sheets of neoprene.  I'll post pics on my restoration thread.  Thanks
Offline Nick in Beds
« Reply #5 on: Monday,September 14, 2015, 05:17:21 AM »
What do you chaps use for the front crossmember padding - and the rear y piece?
Offline Gmg31
« Reply #6 on: Monday,September 14, 2015, 06:01:46 AM »
I wasn't going to use anything.  When I removed the shell the only padding was on the back bone so I wasn't planning to add something that isn't necessary.  I'm planning to fit the neoprene matting recommended above, mine will look like the pictures above but black.
« Reply #7 on: Monday,September 14, 2015, 06:37:19 AM »
That's interesting - I was reading an article in the body section on the page linked below - it is a 74 TCS though so might be different ...
http://www.lotus-europa.com/manuals/
Offline Gmg31
« Reply #8 on: Tuesday,September 15, 2015, 03:12:08 AM »
That's an interesting article.  I had wondered about adding some to the front cross member, I think that's a good idea.  I guess for balance I should add a piece to the Y as well.
« Reply #9 on: Tuesday,September 15, 2015, 07:42:05 AM »
Yes, I think I will too - there is "something" stuck to the body above the front crossmember on mine - not removed it yet, it looks well stuck on ... need to chisel it off and see !!!
Offline Gmg31
« Reply #10 on: Tuesday,September 15, 2015, 10:05:45 AM »
Oh I hadn't thought to look inside the shell, thanks for that. I'll check it out when it comes back.
Offline StrawberryCheesecake
« Reply #11 on: Wednesday,September 16, 2015, 02:44:47 PM »
I started searching for light weight sound proofing mat, and came up with this stuff. Any thoughts?
http://www.ebay.co.uk/itm/Silent-Coat-2mm-10-Sheets-Car-Deadening-Vibration-Sound-Proofing-Damping-Mat-/161282941044?hash=item258d366074
« Reply #12 on: Wednesday,September 16, 2015, 05:11:08 PM »
If you're thinking of something to go between the fame and the body, I think you really want something bigger and a little thicker - say 3/8". That will fit snug so you shouldn't have any sound problems.
If you're thinking of something to put on the floor, I feel like the mat under the carpet works well.
Thinking about it, my engine is pretty loud so maybe I wouldn't know!  :FUNNY:
« Reply #13 on: Wednesday,September 16, 2015, 11:32:41 PM »
This article is what Nick is referring to and there is a cross member piece. It also covers the thickness of material to be used. I am using self adhesive closed cell 13mm neoprene than will compress down down the main chassis
http://www.lotus-europa.com/manuals/misc/body/Optimized%20Jute%20Padding%201974%20TCS%20before%20removal.PDF
Offline Gmg31
« Reply #14 on: Thursday,September 17, 2015, 04:04:56 AM »
I was looking at the sound deadening mats but after the advice on this thread (higher up) I bought three sheets of adhesive backed black closed cell neoprene mats off ebay for £60.  It is superb, very easy to fit and looks great.
