Author Topic: No Lotus Content but Help if you can  (Read 347 times)
Offline Dan C 2624R
« on: Wednesday,August 18, 2021, 01:23:50 PM »
OK, so I have a cleaning problem.  Wife is out to the foodstore via the GMC Yukon and her Driver side mirror  get whacked by a truck meandering over the line.  So Mirror has some kind of fluid for the defog or heat option (oil based ?? anti-freeze??).  Now have Yellow fluid all over the D/S door and glass and down the side.  Due to time lag getting to her and switching cars, it dried in place.  Car is white.
I've exhausted the cleaners I have: Car wash, Dawn detergent, Fantastic,  couple others.  No luck.  Still have a residue on glass and visible on the body.
Any ideas from the collective??
Thanks in advance.
Dan
2624R  TC
Re: No Lotus Content but Help if you can
« Reply #1 on: Wednesday,August 18, 2021, 01:42:56 PM »
Try soaking kitchen paper towel in petrol/gasoline and carefully rubbing the stain.
Take care where you put the paper afterwards.
« Reply #2 on: Wednesday,August 18, 2021, 04:25:09 PM »
   Fluid stain , try a mineral spirts or rubbing alcohol. If that doesn’t work try some lacquer thinner.
If it need something stronger use some rubbing compound by hand .
« Reply #3 on: Wednesday,August 18, 2021, 06:33:09 PM »
WD-40 may work.....It will take off tar, sticker goo etc
Offline Dan C 2624R
« Reply #4 on: Wednesday,August 18, 2021, 07:11:18 PM »
Thanks all.
Going to try Mineral Spirits first.  I have WD-40 will give it a shot also.  Polishing Compound is also on the list to try.
Should be fun.  Most is on D/S door as it dripped to running board but spots all the way down the side as the wife drove off a bit to get to a safe spot to pull over.
Tomorrow will tell.
Offline Dan C 2624R
« Reply #5 on: Friday,August 20, 2021, 03:18:02 PM »
So I still do not know what the fluid is but I do know it was not bothered by any cleaner I had as well as gasoline.
Could not find any mineral spirits and decided to just give Polishing Compound a go.
This was successful in getting  the stains removed.  Did not work well on the Plastic running board but everything else was good.
Appreciate the help.
Dan.
